HPS: How to create buttons/operators using subwindows
Below is sample code on how to create buttons using HPS API.
Sample code can be tested using hps_mfc_sandbox. Please replace the following functions in CHPSView.cpp.
Steps:
  1. Build and run hps_mfc_sandbox with sample code
  2. Click on UserCode3 (setup buttons)
  3. Load any model
  4. Click on button to activate corresponding operator
Notes:
We have an overload function to SetSubwindow(Rectangle const & position, IntRectangle const & offsets, Subwindow::Type type) which will make your buttons remain the same size.
The position values are still given as [-1,1] floats relative to the parent, but the offsets are pixel values relative to those.
Position gives a fractional location (where you measure from) and offset moves a fixed distance from that.For instance, you could make a subwindow that is always inset 25 pixels from its parent by specifying (-1,1,-1,1) & (25,-25,25,-25).
A 100x80 box stuck to the top-left corner would be (-1,-1,1,1) & (0, 100,-80,0).
A 10 pixel high along the top middle third of the parent would be (-0.333,0.333,1,1) & (0,0,-10,0).
Let’s say the two boxes are 50x50, 75 pixels from the bottom, and they are a bit left of center (let’s say centered about x = -0.1), one box could be (-0.1,-0.1,-1,-1) & (-50,0,75,126) and the other (-0.1,-0.1,-1,-1) & (0, 50, 75,125).
// Sample code to create two button on bottom of the scene
void CHPSView::OnUserCode2()
    HPS::SegmentKey subWindowSegment = GetCanvas().GetFrontView().GetSegmentKey().Down("subwindow", true);
	Point points[4] = { Point(0, 0, 0), Point(2, 0, 0), Point(2, 2, 0), Point(0, 2, 0) };
	int faces[5] = { 4, 0, 3, 2, 1 };
	subWindowSegment.GetTextAttributeControl().SetSize(6, HPS::Text::SizeUnits::Pixels).SetAlignment(Text::Alignment::Center);
	subWindowSegment.GetVisibilityControl().SetFaces(true).SetEdges(true).SetLights(false);
	HPS::SubwindowKit subwindowKit;
	subwindowKit.SetSubwindow(HPS::Rectangle(0,0, -1, -1),HPS::IntRectangle(-150, 0, -25, 100), HPS::Subwindow::Type::Lightweight);
	subWindowSegment.Subsegment("panOperator").InsertShell(4, points, 5, faces);
	subWindowSegment.Subsegment("panOperator").GetMaterialMappingControl().SetFaceColor(HPS::RGBAColor(0, 1, 0));
	subWindowSegment.Subsegment("panOperator").InsertText(HPS::Point(1, 1, 0), "PAN");
	subWindowSegment.Subsegment("panOperator").SetSubwindow(subwindowKit);
	HPS::SubwindowKit subwindowKit2;
	subwindowKit2.SetSubwindow(HPS::Rectangle(-0, 0, -1, -1), HPS::IntRectangle(-75, 50, -25, 100), HPS::Subwindow::Type::Lightweight);
	subWindowSegment.Subsegment("zoomOperator").InsertShell(4, points, 5, faces);
	subWindowSegment.Subsegment("zoomOperator").GetMaterialMappingControl().SetFaceColor(HPS::RGBAColor(0, 1, 0));
	subWindowSegment.Subsegment("zoomOperator").InsertText(HPS::Point(1, 1, 0), "ZOOM");
	subWindowSegment.Subsegment("zoomOperator").SetSubwindow(subwindowKit2);
	HPS::CameraKit cameraKit;
	cameraKit.SetUpVector(Vector(0, 1, 0));
	cameraKit.SetPosition(Point(0, 0, -10));
	cameraKit.SetTarget(Point(0, 0, 0));
	cameraKit.SetField(4, 4);
	cameraKit.SetProjection(HPS::Camera::Projection::Orthographic);
	subWindowSegment.SetCamera(cameraKit);
	//GetCanvas().GetFrontView().GetOperatorControl().Pop();
	//GetCanvas().GetFrontView().GetOperatorControl().Push(new MyOperatorControl(GetCanvas()), HPS::Operator::Priority::High);
// Sample code to test if button was selected
void CHPSView::OnLButtonDown(UINT nFlags, CPoint point)
	Point pixelPoint(point.x, point.y, 0);
	Point windowPoint;
	GetCanvas().GetWindowKey().ConvertCoordinate(HPS::Coordinate::Space::Pixel, pixelPoint, HPS::Coordinate::Space::Window, windowPoint);
	GetCanvas().GetWindowKey().GetSelectionOptionsControl().SetLevel(HPS::Selection::Level::Entity); // choosing entity-level selection
	GetCanvas().GetWindowKey().GetSelectionOptionsControl().SetProximity(0.01f);
	GetCanvas().GetWindowKey().GetSelectionOptionsControl().SetAlgorithm(HPS::Selection::Algorithm::Analytic);
	HPS::SelectionResults selectionResults;
	size_t numSelectedItems = GetCanvas().GetWindowKey().GetSelectionControl().SelectByPoint(  // this is the actual selection call
		windowPoint,        // the endpoint of the ray, typically the camera location
		selectionResults);
    // Check if button was button selected
	HPS::SelectionResultsIterator iter = selectionResults.GetIterator();
	while (iter.IsValid())
		HPS::SelectionItem selectionItem = iter.GetItem();
		Key key;
		selectionItem.ShowSelectedItem(key); // 'key' is the HPS::Key of the selected item
		if (key.Type() == HPS::Type::ShellKey)
			// do something with this key
			HPS::SegmentKey ownerSegment = key.Owner();
			if (ownerSegment.Name() == "panOperator")
				GetCanvas().GetFrontView().GetOperatorControl().Push(new HPS::PanOperator(MouseButtons::ButtonLeft()));
                // Highlight button
                // Please see Highlight section for sample code.
			if (ownerSegment.Name() == "zoomOperator")
				GetCanvas().GetFrontView().GetOperatorControl().Push(new HPS::ZoomOperator(MouseButtons::ButtonLeft()));
				// Highlight button
		iter.Next();
	SetCapture();
	_canvas.GetWindowKey().GetEventDispatcher().InjectEvent(
		BuildMouseEvent(HPS::MouseEvent::Action::ButtonDown, HPS::MouseButtons::ButtonLeft(), point, nFlags, 1));
	CView::OnLButtonDown(nFlags, point);
