Can't install hoops_ai using the hoops-ai-installer
Hi!
hoops_ai doesn’t get installed when running hoops-ai-installer, here’s the error:
📦 Installing HOOPS packages...
📋 Loaded companion versions from hoops_packages.config
📌 Installing hoops_ai with version range: hoops_ai>=1.0.0,<1.1.0
📡 Index URL: https://pypi.org/simple
📡 Extra index URL: https://packages.techsoft3d.com/pip
📦 Installing all modules
   ❌ Failed to install HOOPS AI - Foundation package
   Error: ERROR: Could not find a version that satisfies the requirement
hoops_ai<1.1.0,>=1.0.0 (from versions: none)
ERROR: No matching distribution found for hoops_ai<1.1.0,>=1.0.0
I used these commands for installation:
pip install hoops-ai-installer --extra-index-url https://packages.techsoft3d.com/pip
hoops-ai-installer install --mode cpu --extra-index-url https://packages.techsoft3d.com/pip
As far as I understand, the installation command that I’m using is wrong, the docs say that I should be using the command which I received in my email. But I didn’t receive any email like that.
Could someone help me out with this?
Thanks!
Did you also finish the prerequisites and environment setup as mentioned on this page?
Yes, I finished the perquisites and the environment setup.
In order to better assess this incident. Please share the following technical details.
OS you are running.
System architecture.
The output of the following command:
Conda –version
Python –version
pip show hoops-ai-installer
Where we can see the hoops-ai-installer version installed in your pc.
Any other detail you might find relevant for us to share
Thanks
Here are the technical details:
OS - macOS 26.4
System Architecture - ARM
conda version - 26.1.1
python version - 3.12.12
Result of pip show hoops-ai-installer:
Version: 1.0.0
Summary: One-command installer for HOOPS AI (CPU & GPU)
Home-page: https://www.techsoft3d.com
Author:
Author-email: TechSoft3D <support@techsoft3d.com>
License: Proprietary
Location: /Users/abi/.pyenv/versions/3.12.12/lib/python3.12/site-packages
Requires: click, packaging, PyYAML, requests, rich
Required-by:
Hi Abi,
unfortunately HOOPS AI does not support MACOS. You can see the supported plateforms in our doc: Supported Platforms — HOOPS AI 1.0
I can not provide any date estimation for a Mac version since that is not in our short-term roadmap.
Have a nice day!
ah alright, thanks for the clarification!
