HOOPS EXCHANGE - disposing memory after traversing annotations and views
Could you help me to release memory after using following parts of code which are identical to sample Viewer’s code of HOOPS Exchange, TreeTraverse.cpp:
A3DUns32 uNbAnnotationEntity = m_sProductOccurrenceData.m_uiAnnotationsSize;
for (uI = 0; uI < uNbAnnotationEntity; uI++)
A3DMkpAnnotationEntityConnector sAnnotationEntityConnector(m_sProductOccurrenceData.m_ppAnnotations[uI]);
sAnnotationEntityConnector.TraverseAnnotationEntity(psVisitor);
, and:
for (uI = 0; uI < uNbView; uI++)
A3DMkpViewConnector sMkpViewConnector(m_sProductOccurrenceData.m_ppViews[uI]);
sMkpViewConnector.TraverseView(psVisitor);
I think it should be done by availabe distructor:
~A3DProductOccurrenceConnector() { A3DAsmProductOccurrenceGet(NULL, &m_sProductOccurrenceData); }
but I collect growing memory leaks with each use. Any hints appreciated.
@michal.sawczuk thanks for submitting a ticket with this question in our support portal. We’ll post a summary here to help others once your questions are answer.
Mike
We have identified a vector of pointers that is not deallocated in HOOPS Exchange Viewer sample after traversing annotation items.
To fix the memory leaks, add the following code in traverse\MarkupTraverse.cpp in the TraverseAnnotationItem function at line 105.
for (auto ptr : asMarkupTessConnector)
delete ptr;
Etienne
