How to use Exporter's WriteSCMaster function to merge multiple SCS files
I control whether the exported file is an SC file or a SCS file by setting the prepare_hattered_part or prepare_hattered_cs_ parts parameter of the Exporter’s WriteSCHatered. When I use the prepare_hattered_cs_ parts parameter, how do I use the Exporter’s WriteSCMaster to merge multiple SCS files into one SCS file? How do I export WriteSCMaster to a SCS file and how do I set the parameters?
Please see our docs on the Client-side shattered workflow, specifically:
…SC master model must be streamed via the HOOPS Stream Cache Server and cannot be an SCS file. An alternative to that approach is “client-side shattered”.
As the above-referenced link to our docs indicates, please refer to the following functions relevant to an SCS shattered workflow:
