Callback subtreeDeleted too late
In my scenario, I have this kind of node hierachy:
nodeA
----|–> someNode
----|—> someNode
----------------|–> nodeB
nodeA is the only node that the end-user can directly interact with (select, delete, etc.).
I added a callback to the viewer to know when nodes are deleted (CallbackMap.subtreeDeleted). If I delete nodeA, then my callback is triggered as expected, but I only get the root node ID of the removed subtree.
However, since I get the notification after the node is deleted, I cannot query the model to know what sub nodes were also deleted.
Is there a way I can setup a callback to be triggered when a node is “about to” be deleted? Or is there a way I can query the Communicator model to know what is the entire subtree that was removed?
Thanks
Hi @alexis.besner !
This functionality isn’t part of the subtreeDeleted callback, so I recommend reading the child nodes just before the delete function is called.
You can do this using the getNodeChildren(nodeId) call recursively: Model — HOOPS Communicator 2023 SP2 U2 Documentation
Here’s a very simple demo of this functionality: https://3dsandbox.techsoft3d.com/?snippet=6EpmpeAy3y9kf1ihzKUSmjv11
Let me know if you have any additional questions or if I’ve misunderstood your question!
