Custom metadata from jt file
Dear support,
I am facing an issue retrieving metadata from jt file. I used hoops c++ functions to retrieve generic attributes (based on sample source code) but some metadata (obviously custom) aren’t retrieved. Hoops Demo Viewer is retrieving them.
Is there a different API (or loading options) to get them?
Thanks
Regards,
Hoops Exchange 2022.SP2.U2 (last supported version for vs2017)
JT Version 10.5
Hi @gabriel.peragine
I am facing similar issue. Could you please help ?
In my case i am getting metadata for some PO items partially only . .
like 11 atribubtes.
But when i check the hoops demo viewer for the same item . the metadata seems to be more with names like designer names and much more infos.
Do i need to search for datas somewhere else. ?
I am using the hoops . (2024.6.0)
Have you tried traversing all Product Occurrences, including the Prototype? You may want to check the CAD file using the default example PRC2XML. If the issue persists when using PRC2XML, could you provide your CAD file for further analysis? Thank you.
Best Regards,
Man
This worked perfectly well for me. What i have missed is getting the attributes for the Prototype type entities . Now i could get all the missing attributes properly .
Thank you so much .
The solution pointed out by @Man works.
Thanks all for your updates.
