Problem
When importing a CAD file with PMI (non-ASCII characters), the text becomes square when viewed in the HOOPS Demo Viewer.
Possible root causes and solutions
- This could be the specific font is not found.
a. SetA3DRWParamsPmiData::m_bAlwaysSubstituteFontto true. And
b. SetA3DRWParamsPmiData::m_pcSubstitutionFontto a specific font. For example, for Japanese characters, you can set “Yu Gothic”.
c. The font name is written in C:\Windows\Fonts
d. If the font is not installed in the system directory. You should set the font path to A3DRWParamsPmiData::m_ppcProprietaryFontDirectories and path array size A3DRWParamsPmiData::m_uiProprietaryFontDirectoriesSize
- This font is only installed for a single user.
a. Fonts installed on windows for a single user end up in a hidden user directory and they show up when boarding Windows/Fonts even though the file is not located there.
b. Try install the font for all users.
- Last but not least, you need to restart the application or reopen the project (visual studio).
a. Sometimes, some software tends to cache the system environment, including paths and fonts
