Shaders are functions or small scripts that the GPU executes to render data on the screen. HOOPS Communicator includes several common shaders used in engineering applications, enabling common rendering styles in many domains.
If you need to create your own rendering style within your application, custom shaders might be necessary.
Share your thoughts on whether adding custom shaders would be valuable for your application in the comments below.
