HOOPS Communicator server with HTTPS (SSL)
Hi,
This article is written using a public DNS.
As you can see in this article: How to setup HTTPS server with AWS
certificate file is needed to be created using a valid DNS.
In fact, you error message says:
“Hostname/IP does not match certificate’s altnames: IP: 127.0.0.1 is not in the cert’s list:”,
your certificate file seems to be not compatible with localhost (127.0.0.1).
Could you try to configure a HTTPS environment using a public DNS?
This article seems to be for localhost environment, How-To : Using HOOPS Communicator with SSL
Best regards,
Toshi
