Firstly, i’m so soory for my title! I have modified!
When i upload a SCS Files which i generated by Sc API from “D:\Projects\HOOPS_Communicator_2025.6.1\authoring\libsc\examples\sc_store_cube_sample.cpp”, then I find the nodeId is negative!Why?
I find the attributes type is a array,so how should i get the attribute?attributes[0]? It’s error!
Also, when I run the sample, the node id for the cube is positive, not negative. A quick recommendation is that for each time you run the example, please delete the old version in HOOPS_Communicator_2025.6.1\quick_start\converted_models\authoring_samples_data.
attributes.zip (23.2 KB)
Hello,tino:
Sorry for my question!
I deleted the old version, then i get the positive nodeId,but i don’t get the faceattributes, and i test all faces, the results are null. God, why? Help me! Respectfully yours!
Jenson
Sorry, I may not have described my question clearly. Actually, the SCS files in the compressed file have already been generated using the parameter body_id not the parameter “1”. But the results are null.
Best wishes!
Jenson
