When I load SCS files using Model.loadSubtreeFromScsXmlBuffer , I get duplicate nodes in the tree. How can I fix this?
Any insights or suggestions would be appreciated!
Hello @18234083588,
It looks like you are following a shattered workflow. In which case, the hierarchy will include separate nodes representing instances (such as NodeType.PartInstance and NodeType.BodyInstance). This is normal in shattered workflow.
If you want to have a flatter tree hierarchy, a monolithic workflow would probably work better.
Thank you for your response!
