In this article we’re going to describe changing way of display unit and decimal place of dimension created using measurement operators in the Web Viewer run-time.
Builtin measurement operators such as MeasureEdgeLengthOperator and MeasurePointPointDistanceOperator don’t have APIs for customizing display unit and decimal place.
However, it is possible to change the display style using callback function of Web Viewer API in run time.
Instructions
It is possible to rewrite measurement text using the measurementValueSet callback.
The measurementValueSet is called including MeasureMarkup object when the measurement value is set but before it is displayed to the user.
The MeasureMarkup provides APIs which get and set precise value and unit of current dimension.
Here is code snippet
viewer.setCallbacks({
measurementValueSet:(measureMarkup)=> {
// Get dimension value and unit
let value = measureMarkup.getMeasurementValue();
const unit = measureMarkup.getUnitMultiplier();
// Change value's unit to inch
switch (unit) {
// mm => inch
case 1:
value /= 25.4;
break;
// m => inch
case 1000:
value /= 0.0254;
break;
default:
break;
// Make dimension text in 3 decimal place
const dimText = String(Math.floor(value * 1000) / 1000) + ' in';
// Rewrite dimension text
measureMarkup.setMeasurementText(dimText);
measurementValueSet is common callback for all measure operators. You can know active measure operator using MeasureMarkup.getName() or getClassName() method.
i.e.) getName returns “MeasureStraightEdgeLength” when MeasureEdgeLengthOperator is running.
