** Edit (2/17/25): click here for an updated version of this guide. **
** Original post is below **
We recently released ESM for Communicator for an improved development experience.
Here is a guide for setting up Communicator ESM with TypeScript in Next.js, a full-stack React framework.
Note: This guide was created for HOOPS Communicator 2024.4.0 and instructions may vary in future releases.
Initial Setup
Download HOOPS Communicator from https://manage.techsoft3d.com/ or our Developer zone if you are an existing partner.
Create an empty directory for your project and open Visual Studio Code or your preferred IDE. (The rest of this tutorial will be based on Visual Studio Code.)
Open a terminal and run
npx create-next-app@latest.
Apply your desired configuration as shown above. More info on configuration related to Next.js can be found in the Next.js documentation.
cdto the new<Next_App>directory created (test_app_tsin this case) and runnpm run devto start the development server to view the app and verify successful installation. -
Create a directory under
<Next_App>/appcalledhoops. -
Copy
<Communicator_Install_Directory>/web_viewer/typesto this directory. -
Copy
<Communicator_Install_Directory>/web_viewer/hoops-web-viewer-monolith.mjsto<Next_App>/app/hoops/types/web-viewer.
Note: we are using the monolith version of the web viewer here for simplicity. The non-monolithic version will require additional configuration at this time, which we will not cover in this guide.
- Create a new file called
package.jsonin<Next_App>/app/hoops/types/web-viewerand paste the following:
"name": "@hoops/web-viewer",
"version": "0.0.1",
"main": "./hoops-web-viewer-monolith.mjs",
"typings": "./index.d.ts"
Communicator Integration
Create a viewer component
Copy microengine.scs from
<Communicator>/quick_start/converted_models/standard/scsto a new directory called<Next_App>/public/models. -
Create a directory in
<Next_App>/appcalledcomponents. -
Create
Viewer.tsxhere and create an empty basic component:
export default function Viewer() {
return (
- At the top of the file, add the
'use client'directive to support the web viewer and React functionalities. Also, include the module imports for this basic demo:
'use client'
import * as Communicator from '../hoops/types/web-viewer';
import { useState, useEffect } from 'react';
- Within the
Viewerfunction, create a variablehwvfor the viewer and a container (div element) for the viewer:
let hwv : Communicator.WebViewer;
return (
<div id="viewer"></div>
(If you’d like to confirm your setup, scroll to the bottom for the completed files.)
- Above the
returnin that function, add astartViewerfunction:
function startViewer(container: string, model: string) {
hwv = new Communicator.WebViewer({
containerId: container,
endpointUri: model
window.onresize = () => {
hwv.resizeCanvas();
hwv.start();
return hwv;
- We’ll want this function executed once the page has rendered, so we can use
useEffectto call it. Add this before everything else you’ve defined in theViewerfunction:
useEffect(() => {
let hwv = startViewer("viewer", "./models/microengine.scs");
return () => {
hwv.shutdown();
Note the use of the cleanup function (see https://react.dev/learn/synchronizing-with-effects#how-to-handle-the-effect-firing-twice-in-development) for info).
Render the component
- Delete all contents in
<Next_App>/app/page.jsand replace with the following so just theViewercomponent is rendered:
import Viewer from './components/Viewer';
export default function Home() {
return (
<Viewer />
- Check your app by running
npm run dev:
Note: You may see error messages in the terminal. This is a known issue and a resolution is being worked on.
Using State
Next, we will create a simple demo of using State to change what’s on the web page. Specifically, we will display the node ID of the most recently clicked node in the lower right corner of the screen:
- In
Viewer.tsxin theViewerfunction, add the following before theuseEffect:
const [nodeId, setNodeId] = useState<number | null>(null);
- In the
startViewerfunction, add a callback to set thenodeIdstate to the most recently clicked node. Add the following immediately beforehwv.start():
hwv.setCallbacks({
selectionArray: (selEvents)=>{
if (selEvents.length > 0){
const lastSelectedNode = selEvents[0].getSelection().getNodeId();
setNodeId(lastSelectedNode);
else {
setNodeId(null);
- Finally, add the HTML elements to display the
nodeIdby adding the following in thereturnstatement, just after theviewerdiv:
<div id="nodeDisplay" style={{position: "absolute", bottom: "10px", right: "10px", fontSize: "18px", padding: "10px"}}>
<p id="nodeDisplayText">{"Node ID: " + nodeId}</p>
</div>
- Run
npm run devand notice the “Node ID” display changes based on the last node that’s clicked.
Summary
Directory structure:
Viewer.tsx
'use client'
useEffect(()=>{
// Cleanup
return () => {
hwv.shutdown();
endpointUri: model
hwv.resizeCanvas();
hwv.setCallbacks({
else {
setNodeId(null);
hwv.start();
return hwv;
return (
</div>
Please let me know if you have questions or run into any issues with setting up HOOPS Communicator.
Feel free to share any of your own tips as well!
