To programmatically create a “Fit visible” camera, you will compute its value using the model bounding box. In this sample code below you can see a simple way to compute a fit world view
“Default” camera
A3DMiscComputeBoundingBoxwill compute a Bounding Box for the model.- Then we compute the center of the bounding box. It will be the camera center.
- Finally we make a position for the camera. Here I computed a vector from the center position, but you may adjust the values to find the best fitting for your usage.
- We use the camera in the HOOPS Publish sample UserDefinedViews.
A3DBoundingBoxData pboxdata;
A3D_INITIALIZE_DATA(A3DBoundingBoxData, pboxdata);
A3DMiscComputeBoundingBox(pModelFile, 0, &pboxdata);
double centerx, centery, centerz;
centerx = pboxdata.m_sMax.m_dX - pboxdata.m_sMin.m_dX;
centery = pboxdata.m_sMax.m_dY - pboxdata.m_sMin.m_dY;
centerz = pboxdata.m_sMax.m_dZ - pboxdata.m_sMin.m_dZ;
double positionx, positiony, positionz;
positionx = centerx + 0.5 * centerx;
positiony = centery + 0.5 * centery;
positionz = centerz + 0.5 * centerz;
// Default view: no button for this default view
CHECK_RET(CreateView(pDoc, p3DArtwork,
positionx, positiony,positionz, // camera position
centerx, centery, centerz, // target position
0,0,0, // up vector unused - roll is used instead
0, // roll
kA3DPDFPerspectiveMode, 0, 30,
true, viewnameDef, &pViewDef));
