How to construct a model with multiple configurations node using libSC?
The Solidworks model supports multi-configuration functionality, which is also supported in HOOPS EXCHANGE. If I want to build a multi-configuration model using libSC, what should I do?
Thanks.
Hello @820110017,
The multi-configuration feature of SolidWorks file is not supported in libSC authoring. If you wish, you can create a feature request in our Support Portal.
