Below is sample code on how to edit shell’s vertex using a custom operator.
class MyOp : public HBaseOperator
public:
HBaseView *myView;
HC_KEY planeSegment;
HC_KEY shellKey;
bool operator_selected;
MyOp(HBaseView* view, int DoRepeat = 0, int DoCapture = 1);
void CreatePlane();
int OnLButtonDown(HEventInfo &event);
int OnLButtonDownAndMove(HEventInfo &event);
int OnLButtonUp(HEventInfo &event);
MyOp::MyOp(HBaseView* view, int DoRepeat, int DoCapture) : HBaseOperator(view, DoRepeat, DoCapture)
myView = view;
CreatePlane();
int MyOp::OnLButtonDown(HEventInfo &event)
// check to see if marker handles is selected
HPoint window = event.GetMouseWindowPos();
int count = 0;
HC_KEY key;
int offset1, offset2, offset3;
float selection_offset = 0.01f;
HC_Open_Segment_By_Key(m_pView->GetViewKey());
count = HC_Compute_Selection_By_Area(".", ".", "v",
window.x - selection_offset, window.x + selection_offset,
window.y - selection_offset, window.y + selection_offset);
if (count > 0)
HC_Show_Selection_Element(&key, &offset1, &offset2, &offset3);
char owner[128];
HC_Show_Owner_By_Key(key, owner);
if (strstr(owner, "marker_handles"))
operator_selected = true;
m_pView->Update();
HC_Close_Segment();
return HOP_OK;
int MyOp::OnLButtonDownAndMove(HEventInfo &event)
// if marker handles is selected, edit marker handle and shell's vertex base on the current mouse position
if (operator_selected == true)
HC_KEY key = INVALID_KEY;
int offset1[10];
int offset2[10];
int offset3[10];
HC_Show_Selection_Element(&key, &offset1[0], &offset2[0], &offset3[0]);
HPoint world;
HC_Open_Segment_By_Key(myView->GetSceneKey()); {
HC_Compute_Coordinates(".", "local window", &window, "world", &world);
} HC_Close_Segment();
char type[128];
HC_Show_Key_Type(key, type);
if (streq(type, "marker"))
// edit the position of marker
HPoint markerPos;
HC_Show_Marker(key, &markerPos.x, &markerPos.y, &markerPos.z);
HC_Edit_Marker(key, world.x, world.y, world.z);
// Find the vertex using the position of markers handle
// Edit the position of the shell's vertex
int in_point_count, in_face_list_length;
HPoint *in_points;
int *in_face_list;
HC_Show_Shell_Size(shellKey, &in_point_count, &in_face_list_length);
in_points = new HPoint[in_point_count];
in_face_list = new int[in_face_list_length];
HC_Show_Shell(shellKey, &in_point_count, in_points, &in_face_list_length, in_face_list);
int ii=0;
for (ii = 0; ii < in_point_count; ii++)
if (in_points[ii] == markerPos)
HC_Edit_Shell_Points(shellKey, ii, 1, 1, &world);
m_pView->Update();
GetView()->Update();
return HOP_OK;
int MyOp::OnLButtonUp(HEventInfo &event)
operator_selected = false;
return HOP_OK;
// create plane an marker handles on each vertex
// Markers position is equal to shells points
void MyOp::CreatePlane()
planeSegment = HC_Open_Segment("overwrite/plane"); {
int pcount, flist_count;
pcount = 4;
flist_count = 5;
HPoint pts[4];
int faces[5] = { 4, 0, 1, 2, 3 };
pts[0].Set(-1, -1, 0);
pts[1].Set(1, -1, 0);
pts[2].Set(1, 1, 0);
pts[3].Set(-1, 1, 0);
HC_Set_Visibility("faces=on,edges=on,vertices=off");
shellKey = HC_Insert_Shell(pcount, pts, flist_count, faces);
HC_Open_Segment("marker_handles"); {
HC_Set_Visibility("markers=on");
HC_Set_Rendering_Options("depth range=(0,0.1)");
HC_Set_Marker_Size(1);
HC_Insert_Marker(-1, -1, 0);
HC_Insert_Marker(1, -1, 0);
HC_Insert_Marker(1, 1, 0);
HC_Insert_Marker(-1, 1, 0);
HC_Close_Segment();
myView->Update();
HSelectionSet * selection = new HSelectionSet(m_pHView);
selection->Init();
m_pHView->SetViewSelectionLevel(HSelectionLevelEntity);
m_pHView->SetSelection(selection);
MyOp *my_operator = new MyOp(m_pHView);
m_pHView->SetOperator(my_operator);
m_pHView->SetViewMode(HViewXY);
m_pHView->Update();
