How to detect and clean corrupt .scz files in NodeJS (server-side)
Hi all,
We’re using HOOPS Communicator with a Service pod that downloads .scz (scene) files on-demand from a file service. The flow is:
  1. UI requests a model from Server side.
  2. Server downloads the .scz file and caches it locally.
  3. UI tries to load the .scz using loadSubtreeFromScz() (client API).
Problem:
  • If the .scz file is corrupt, the client sees a bad model key error.
  • The corrupt file remains in the pod cache, so every future request fails.
  • Service has no access to loadSubtreeFromScz(), because it’s a client-side API.
Question:
What’s the best approach to detect and clean corrupt .scz files on the server side before they reach the client?
We are thinking about:
  • Validating the .scz as a ZIP archive immediately after download.
  • Checking for manifest.json and basic internal structure.
  • Deleting the file if validation fails.
Has anyone implemented a server-side integrity check for .scz files in a similar HOOPS Communicator setup? Any best practices or ready-to-use patterns for Server side?
Hello @raja.r,
Well, on the server side, the converter has a list of error codes that may be helpful — please see Error Codes in our docs.
Also, there is a callback called modelLoadFailure which triggers on the client. You will have to capture the result and send it back to the server and handle it.
