Below is sample code on how to create a Legend using subwindow.
When you re-size the main window, the size of the Legend does not change.
HPS::SubwindowKit subwindowKit;
// set a anchor point on top-left corner of the main window
// HPS::IntRectangle(left, right, down, up) represent the size of your subwindow in pixels.
subwindowKit.SetSubwindow(HPS::Rectangle(-1, -1, 1, 1), HPS::IntRectangle(0, 150, -400, 0), HPS::Subwindow::Type::Lightweight);
// set a anchor point on top-right corner of the main window
// subwindowKit.SetSubwindow(HPS::Rectangle(1, 1, 1, 1), HPS::IntRectangle(-150, 0, -400, 0), HPS::Subwindow::Type::Lightweight);
// set a anchor point on bottom-left corner of the main window
// subwindowKit.SetSubwindow(HPS::Rectangle(-1, -1, -1, -1), HPS::IntRectangle(0, 150, 0, 400), HPS::Subwindow::Type::Lightweight);
// set a anchor point on bottom-right corner of the main window
// subwindowKit.SetSubwindow(HPS::Rectangle(1, 1, -1, -1), HPS::IntRectangle(-150, 0, 0, 400), HPS::Subwindow::Type::Lightweight);
HPS::SegmentKey anotherSegmentKey = GetCanvas().GetFrontView().GetSegmentKey().Down("subwindow", true);
anotherSegmentKey.SetSubwindow(subwindowKit);
anotherSegmentKey.GetVisibilityControl().SetEverything(false).SetEdges(true).SetText(true).SetVertices(true);
//Read in Legend.hsf
HPS::Stream::ImportNotifier importNotifier;
try {
HPS::Stream::ImportOptionsKit importOptionsKit;
importOptionsKit.SetSegment(anotherSegmentKey); // set destination segment
importNotifier = HPS::Stream::File::Import("D:/legend.hsf", importOptionsKit);
// the notifier can be used to check the load progress
float percent_complete;
importNotifier.Status(percent_complete);
// pauses this thread until the HSF is finished loading
importNotifier.Wait();
catch (HPS::IOException ioe) {
// handle exception
throw;
// setting the camera using the CameraControl and method chaining
anotherSegmentKey.GetCameraControl()
.SetUpVector(Vector(0, 1, 0))
.SetPosition(Point(0, 0, 1))
.SetTarget(Point(0, 0, 0))
.SetField(0.5f, 0.5f)
.SetProjection(HPS::Camera::Projection::Orthographic);
// Dolly camera to fit legend inside sub-window
anotherSegmentKey.GetCameraControl().Dolly(-0.2, -0.7, 0);
**Video **
Legend.hsf file :
legend.zip (4.2 KB)
