Introduction
In this article, we’re going to describe updating the PRC model file structure using the example of splitting a multi-body part into an assembly model.
If you import helloworld.stp in <HOOPS_Exchange_Publish SDK dir>\samples\data\step using HOOPS Demo Viewer (HDV), you will see the part has 10 bodies. Through this article, you can split the multi-body part into an assembly model, including multiple parts.
Instructions
Workbench project preparation
- Refer How-to: Traverse PRC model file using Visitor pattern for rapid prototyping article and create a workbench project (form [Workbench project preparation] to [Implement tree traverse function])
Derived class creation
Create a derived class of A3DTreeVisitor for this use case.
- Create a derived class of A3DTreeVisitor including
visitEntermethod forA3DPartConnector
static MY_CHAR acLogFileName[_MAX_PATH * 2];
class bodyOperationVisitor: public A3DTreeVisitor
public:
bodyOperationVisitor(A3DVisitorContainer* psContainer = NULL) : A3DTreeVisitor(psContainer) {};
~bodyOperationVisitor() {};
public:
virtual A3DStatus visitEnter(const A3DPartConnector& sConnector) override
A3DStatus iRet = A3DTreeVisitor::visitEnter(sConnector);
// My processes
return iRet;
void traverseModelFile(A3DAsmModelFile* pModelFile)
- Use the derived
bodyOperationVisitorclass instead ofA3DTessVisitorin thetraverseModelFilefunction
// Prepare body operation visitor and set to the container
bodyOperationVisitor *pBodyOpVisitor = new bodyOperationVisitor(&sA3DVisitorContainer);
sA3DVisitorContainer.push(pBodyOpVisitor);
- Build the project
- Create break points in the
bodyOperationVisitorclass and verify that the class is called during run time
Thanks to the bodyOperationVisitor, you can add inquiry and update functions while model file traversing.
Implementing functions and timing for splitting multi body part will be the following image:
Detecting a multi body part and splitting the parts
If m_uiRepItemsSize of the Part Definition is more than 1, it means you have a multi body part.
- Add code to detect multi body part and split into individual parts
public:
// Get the PartDefiniiton data
A3DAsmPartDefinitionData sData = sConnector.m_sPartData;
// Detect multi body part
if (1 < sData.m_uiRepItemsSize)
// It is multi body part
return iRet;
- Split the multi body into new parts
private:
int m_iBodyCnt;
A3DAsmPartDefinition** m_ppPart;
public:
m_iBodyCnt = 0;
m_iBodyCnt = sData.m_uiRepItemsSize;
// Create new Parts for each body
m_ppPart = new A3DAsmPartDefinition*[m_iBodyCnt];
for (A3DUns32 ui = 0; ui < m_iBodyCnt; ui++)
// Create a new part and set body
A3DAsmPartDefinitionData sNewPartData;
A3D_INITIALIZE_DATA(A3DAsmPartDefinitionData, sNewPartData);
sNewPartData.m_uiRepItemsSize = 1;
sNewPartData.m_ppRepItems = &sData.m_ppRepItems[ui];
iRet = A3DAsmPartDefinitionCreate(&sNewPartData, &m_ppPart[ui]);
return iRet;
Creating an assembly model file
In the above code, when a multi body part is detected, the m_iBodyCnt member variable is set. The first visitLeave of Product Occurrence after setting the body count will be the Product Occurrence of the target part.
- Add
visitLeavemethod of Product Occurrence and create an assembly model including the split parts whenm_iBodyCntis greater than 1.
private:
int m_iBodyCnt;
A3DAsmProductOccurrence* m_pAssyPO = NULL;
virtual A3DStatus visitLeave(const A3DProductOccurrenceConnector& sConnector) override
A3DStatus iRet = A3D_SUCCESS;
// Get the ProductOccurrence (PO)
const A3DEntity* pEntity = sConnector.GetA3DEntity();
A3DAsmProductOccurrence* pPO = (A3DAsmProductOccurrence*)pEntity;
// Get PO data
A3DAsmProductOccurrenceData sData = sConnector.m_sProductOccurrenceData;
// Get RootBaseData of the PO
A3DRootBaseData sRootBaseData;
A3D_INITIALIZE_DATA(A3DRootBaseData, sRootBaseData);
A3DRootBaseGet(pPO, &sRootBaseData);
// If multi body part
if (m_iBodyCnt)
// Create new POs of the new parts
A3DAsmProductOccurrence **ppPO;
ppPO = new A3DAsmProductOccurrence*[m_iBodyCnt];
// Create new PO
A3DAsmProductOccurrenceData sPOData;
A3D_INITIALIZE_DATA(A3DAsmProductOccurrenceData, sPOData);
sPOData.m_dUnit = sData.m_dUnit;
sPOData.m_pPart = m_ppPart[ui];
iRet = A3DAsmProductOccurrenceCreate(&sPOData, &ppPO[ui]);
// Set part name (org name - id)
char name[1024];
sprintf_s(name, sizeof(name), "%s - %d", sRootBaseData.m_pcName, ui + 1);
A3DRootBaseData sNewBaseData;
A3D_INITIALIZE_DATA(A3DRootBaseData, sNewBaseData);
sNewBaseData.m_pcName = name;
iRet = A3DRootBaseSet(ppPO[ui], &sNewBaseData);
// Create a new assembly PO for split parts
A3DAsmProductOccurrenceData sNewPOData;
A3D_INITIALIZE_DATA(A3DAsmProductOccurrenceData, sNewPOData);
sNewPOData.m_uiPOccurrencesSize = m_iBodyCnt;
sNewPOData.m_dUnit = sData.m_dUnit;
sNewPOData.m_ppPOccurrences = ppPO;
sNewPOData.m_pLocation = sData.m_pLocation;
iRet = A3DAsmProductOccurrenceCreate(&sNewPOData, &m_pAssyPO);
iRet = A3DRootBaseSet(m_pAssyPO, &sRootBaseData);
iRet = A3DTreeVisitor::visitLeave(sConnector);
return iRet;
- Add
visitLeavemethod of model file and create a new model file when an assembly model is created in the previous process.
static A3DAsmModelFile *s_pNewModelFile = NULL;
class bodyOperationVisitor : public A3DTreeVisitor
virtual A3DStatus visitLeave(const A3DModelFileConnector& sConnector) override
A3DAsmModelFile* pModelFile = (A3DAsmModelFile*)pEntity;
A3DAsmModelFileData sData = sConnector.m_sModelFileData;
A3DRootBaseGet(pModelFile, &sRootBaseData);
if (m_pAssyPO)
// Create assemly pModelFile
A3DAsmModelFileData sModelFileData = sConnector.m_sModelFileData;
sModelFileData.m_bUnitFromCAD = sData.m_bUnitFromCAD;
sModelFileData.m_dUnit = sData.m_dUnit;
sModelFileData.m_eModellerType = kA3DModellerPrc;
sModelFileData.m_uiPOccurrencesSize = 1;
sModelFileData.m_ppPOccurrences = &m_pAssyPO;
iRet = A3DAsmModelFileCreate(&sModelFileData, &s_pNewModelFile);
// Set root made data of original model file
iRet = A3DRootBaseSet(s_pNewModelFile, &sRootBaseData);
m_pAssyPO = NULL;
return iRet;
If you update a node of model file, it is necessary to update it at end of traversing (
visitLeave) . If you update a node at beginning of traversing (visitEnter), it affect its child nodes traversing and cause of application crash.
Replacing the model file
Apart from the imported model file, a new model file (s_pNewModelFile) is created in the above code.
- After traversing the model file, replace the original model file when the new model file is created.
traverseModelFile(sHoopsExchangeLoader.m_psModelFile);
if (NULL != s_pNewModelFile)
A3DStatus iRet = A3DAsmModelFileDelete(sHoopsExchangeLoader.m_psModelFile);
sHoopsExchangeLoader.m_psModelFile = s_pNewModelFile;
- Build the project
- Verify that multi body part is split into assembly model
Multi body parts in assembly model
The above code just supports multi body part model file. If you open the _LandingGear.CATProduct in the ‘<HOOPS_Exchange_Publish SDK dir>\samples\data\catiaV5\CV5_Landing Gear Model’ directory using the HDV, you will see some multi body parts in the assembly model file.
In an assembly model file, though it is necessary to replace detected multi body part (step 4 in below image) to assembly model (step 6), the timing (step 13) is a bit complicated.
- Prepare member array of struct to keep target POs and assembly models
#include <sstream>
#include <vector>
struct SplitPart
const A3DAsmProductOccurrence *parentPO;
A3DAsmProductOccurrence *oldPartPO;
A3DAsmProductOccurrence *newAssyPO;
std::vector<SplitPart> m_aSplitPart;
- Try to get father PO to check whether the model file is part model file or assembly model file
if (m_iBodyCnt)
// Access father PO
const A3DAsmProductOccurrence *pParentPO = sConnector.GetProductOccurrenceFather();
// If father PO isn't null, it is assembly model file
if (NULL != pParentPO)
// Keep the target POs
SplitPart splitPart;
splitPart.parentPO = sConnector.GetProductOccurrenceFather();
splitPart.oldPartPO = pPO;
splitPart.newAssyPO = m_pAssyPO;
m_aSplitPart.push_back(splitPart);
m_pAssyPO = NULL;
// No father PO maens that it is part model file
- Replace multi body part to assembly model in proper timing
if (m_iBodyCnt)
else
// Check whether current PO is in a targets
for (int i = 0; i < m_aSplitPart.size(); i++)
SplitPart splitPart = m_aSplitPart[i];
if (pPO == splitPart.parentPO)
// Find target multi body part PO and replace to assembly PO
for (A3DUns32 ui = 0; ui < sData.m_uiPOccurrencesSize; ui++)
if (sData.m_ppPOccurrences[ui] == splitPart.oldPartPO)
sData.m_ppPOccurrences[ui] = splitPart.newAssyPO;
break;
iRet = A3DAsmProductOccurrenceEdit(&sData, pPO);
return iRet;
- Build the project
- Verify that multi body parts in the assembly model are split into assembly models
Detecting part instances
If you look at converted model in the model browser, you will see some components are instanced.
To manage part instances, each part instance points abstract product occurrence so called “prototype“.
- Add code to get prototype info
if (m_iBodyCnt)
// Get prototype
A3DAsmProductOccurrence *pProtoPO = sData.m_pPrototype;
A3DAsmProductOccurrenceData sProtoData;
A3DRootBaseData sProtoBaseData;
if (NULL != pProtoPO)
A3D_INITIALIZE_DATA(A3DAsmProductOccurrenceData, sProtoData);
iRet = A3DAsmProductOccurrenceGet(pProtoPO, &sProtoData);
A3D_INITIALIZE_DATA(A3DRootBaseData, sProtoBaseData);
iRet = A3DRootBaseGet(pProtoPO, &sProtoBaseData);
- Build the project
- Create a break point and verify that prototype info is received
- Keep the prototype pointer and instance transform in a member variable and detect part instance
struct SplitPart
A3DAsmProductOccurrence *protoPO;
A3DMiscTransformation *instanceTransform;
A3DRootBaseData instanceBaseData;
if (m_iBodyCnt)
// Chenck whether the same part is detected
if (pProtoPO == m_aSplitPart[i].protoPO)
splitPart.newAssyPO = m_aSplitPart[i].newAssyPO;
splitPart.instanceTransform = sData.m_pLocation;
splitPart.instanceBaseData = sRootBaseData;
return iRet;
// sNewPOData.m_pLocation = sData.m_pLocation; <= comment out this line
// Set prototype's RootBaseData
iRet = A3DRootBaseSet(m_pAssyPO, &sProtoBaseData);
splitPart.protoPO = pProtoPO;
- Build the project
- Create a break and verify that part instance is detected
Replacement using sub-assembly prototype
Multi body part should be replaced using sub-assembly prototype like below image
- Update part replacement code
else
// Create new sub-assembly instance
A3DAsmProductOccurrenceData sAssyInstData;
A3D_INITIALIZE_DATA(A3DAsmProductOccurrenceData, sAssyInstData);
sAssyInstData.m_pLocation = splitPart.instanceTransform;
sAssyInstData.m_pPrototype = splitPart.newAssyPO;
A3DAsmProductOccurrence *pAssyInstPO;
iRet = A3DAsmProductOccurrenceCreate(&sAssyInstData, &pAssyInstPO);
// Set RootBaseData of the instance
iRet = A3DRootBaseSet(pAssyInstPO, &splitPart.instanceBaseData);
// Replace part instance to sub-assembly instance
sData.m_ppPOccurrences[ui] = pAssyInstPO;
break;
- Build the project
Here is full source code of ImportExport.cpp for this article
* Copyright (c) 2017 by Tech Soft 3D, LLC.
* The information contained herein is confidential and proprietary to Tech Soft 3D, LLC., and considered a trade secret
* as defined under civil and criminal statutes. Tech Soft 3D shall pursue its civil and criminal remedies in the event
* of unauthorized use or misappropriation of its trade secrets. Use of this information by anyone other than authorized
* employees of Tech Soft 3D, LLC. is granted only under a written non-disclosure agreement, expressly prescribing the
* scope and manner of such use.
* This sample demonstrates how to load a model and export it as a model file of a different format. The chosen
* format is determined by the file extension of the output file name.
#define INITIALIZE_A3D_API
#include <A3DSDKIncludes.h>
#include "common.hpp"
#include <sstream>
#include <vector>
#include "visitor/VisitorContainer.h"
#include "visitor/VisitorTree.h"
static MY_CHAR acSrcFileName[_MAX_PATH * 2];
static MY_CHAR acDstFileName[_MAX_PATH * 2];
public:
private:
int m_iBodyCnt;
struct SplitPart
public:
m_iBodyCnt = 0;
return iRet;
// Get PO data
if (m_iBodyCnt)
// Get prototype
return iRet;
// Create new PO
char name[1024];
// Access father PO
m_pAssyPO = NULL;
else
break;
return iRet;
if (m_pAssyPO)
m_pAssyPO = NULL;
return iRet;
// Prepare Visitor container
A3DVisitorContainer sA3DVisitorContainer(CONNECT_TRANSFO);
sA3DVisitorContainer.SetTraverseInstance(true);
// Prepare Tree traverse visitor and set to the container
// Prepare model file connector and call Traverse
A3DModelFileConnector sModelFileConnector(pModelFile);
A3DStatus sStatus = sModelFileConnector.Traverse(&sA3DVisitorContainer);
#ifdef _MSC_VER
int wmain(A3DInt32 iArgc, A3DUniChar** ppcArgv)
#else
int main(A3DInt32 iArgc, A3DUTF8Char** ppcArgv)
#endif
// ### COMMAND LINE ARGUMENTS
if (iArgc < 2)
MY_PRINTF2("Usage:\n %s [input CAD file] [output CAD file] [output LOG file]\n", ppcArgv[0]);
MY_PRINTF(" Default output CAD file is [input CAD file].prc\n");
MY_PRINTF(" Default output LOG file is [output CAD file]_Log.txt\n\n");
return A3D_ERROR;
if (iArgc > 1) MY_STRCPY(acSrcFileName, ppcArgv[1]);
else MY_STRCPY(acSrcFileName, DEFAULT_INPUT_CAD);
if (iArgc > 2) MY_STRCPY(acDstFileName, ppcArgv[2]);
else MY_SPRINTF(acDstFileName, "%s.prc", acSrcFileName);
if (iArgc > 3) MY_STRCPY(acLogFileName, ppcArgv[3]);
else MY_SPRINTF(acLogFileName, "%s_Log.txt", acDstFileName);
GetLogFile(acLogFileName); // Initialize log file
// ### INITIALIZE HOOPS EXCHANGE
std::wstringstream bin_dir;
#ifdef _DEBUG
std::wstring buffer;
buffer.resize(_MAX_PATH * 2);
if (GetEnvironmentVariable(L"HEXCHANGE_INSTALL_DIR", &buffer[0], static_cast<DWORD>(buffer.size())))
bin_dir << buffer.data() << L"/bin/win64\0";
#else
bin_dir << L"";
#endif
A3DSDKHOOPSExchangeLoader sHoopsExchangeLoader(bin_dir.str().data());
CHECK_RET(sHoopsExchangeLoader.m_eSDKStatus);
// Uncomment these lines to track memory leaks
//CHECK_RET(A3DDllSetCallbacksMemory(CheckMalloc, CheckFree));
CHECK_RET(A3DDllSetCallbacksReport(PrintLogMessage, PrintLogWarning, PrintLogError));
// ### PROCESS SAMPLE CODE
// specify input file
A3DImport sImport(acSrcFileName); // see A3DSDKInternalConvert.hxx for import and export detailed parameters
// specify output file
A3DExport sExport(acDstFileName); // see A3DSDKInternalConvert.hxx for import and export detailed parameters
// perform conversion
CHECK_RET(sHoopsExchangeLoader.Import(sImport));
CHECK_RET(sHoopsExchangeLoader.Export(sExport));
// ### TERMINATE HOOPS EXCHANGE
// Check memory allocations
//if (siCheckMallocCounter != 0)
// fprintf(GetLogFile(), "stiMallocCounter=%d", siCheckMallocCounter);
return A3D_SUCCESS;
