Below is sample code on how to calculate text size to draw a box around it. Please note that text’s ascender/descender are not included in calculation.
HPS also have pre-define background you can use as well.
[Text — HOOPS Visualize HPS 2023 SP2 U2 Documentation](https://Pre-defined backround)
Sample code using hps_mfc_sandbox:
void CHPSView::OnUserCode3()
// TODO: Add your command handler code here
GetCanvas().GetFrontView().GetSegmentKey().GetCameraControl()
.SetPosition(Point(0, 0, 5))
.SetTarget(Point(0, 0, 0))
.SetUpVector(Vector(0, 1, 0))
.SetField(2.5f, 2.5f)
.SetProjection(Camera::Projection::Orthographic);
GetCanvas().GetFrontView().FitWorld().UpdateWithNotifier().Wait();
void CHPSView::OnUserCode4()
Point textPosition(-0.75f, 0.0f, 0.0f);
TextKey text = GetCanvas().GetFrontView().GetAttachedModel().GetSegmentKey().InsertText(textPosition, "Testing");
text.SetFont("roman").SetAlignment(Text::Alignment::Center).SetTransform(Text::Transform::NonTransformable);
float xFrac;
float yFrac;
SprocketPath myPath(GetCanvas());
myPath.GetKeyPath().ComputeTextExtent("Testing", xFrac, yFrac);
Point textWindowPosition;
myPath.GetKeyPath().ConvertCoordinate(Coordinate::Space::Object, textPosition, Coordinate::Space::Window, textWindowPosition);
PointArray textWindowExtentPoints(5);
textWindowExtentPoints[0] = textWindowPosition + Vector(-xFrac, -yFrac, 0);
textWindowExtentPoints[1] = textWindowPosition + Vector(xFrac, -yFrac, 0);
textWindowExtentPoints[2] = textWindowPosition + Vector(xFrac, yFrac, 0);
textWindowExtentPoints[3] = textWindowPosition + Vector(-xFrac, yFrac, 0);
textWindowExtentPoints[4] = textWindowExtentPoints[0];
PointArray textObjectExtentPoints(5);
Coordinate::Space::Window, textWindowExtentPoints, Coordinate::Space::Object, textObjectExtentPoints);
GetCanvas().GetFrontView().GetAttachedModel().GetSegmentKey().Subsegment("text_bound").Flush();
GetCanvas().GetFrontView().GetAttachedModel().GetSegmentKey().Subsegment("text_bound").InsertLine(textObjectExtentPoints);
GetCanvas().GetFrontView().GetAttachedModel().GetSegmentKey().GetVisibilityControl().SetLines(true);
GetCanvas().GetFrontView().UpdateWithNotifier().Wait();
Screenshot:
