I want to save a snapshot of the view. When the path exists, it works fine. But if a folder in the path is not existing, I get an exception. Is there a way to create the missing folders ?
HPS::Image::ExportOptionsKit export_options;
export_options.SetFormat(HPS::Image::Format::Png);
export_options.SetSize(800, 450);
HPS::Image::File::Export("C:/temp/test/testExport.png", GetCanvas().GetWindowKey(), export_options);
simon
March 28, 2024, 8:56pm
2
Hello Julian,
HOOPS does not have a API to create folder.
You can use the following code in C++ 17 to achieve this
#include <filesystem>
int main() {
bool created_new_directory = false;
bool there_was_an_exception = false;
try {
= std::filesystem::create_directory("directory_name");
} catch(std::exception & e){
there_was_an_exception = true;
// creation failed
if ((not created_new_directory) and (not there_was_an_exception)) {
// no failure, but the directory was already present.
Best Regards,
Simon
