I’m experiencing issues with toggling the visibility of my models in my app. The current workflow of the app is:
- Loading static models
- Loading user-custom models
The problem arises when I try to toggle the visibility of some models. When using setNodesVisibility or isolateNodes, it ends up hiding all models in the scene, not just the ones I want to target.
As a workaround, I’m using setNodesOpacity() to hide or show the nodes I need, and it works as expected, this confirms that I’m not incorrectly targeting the nodes since everything functions properly when using opacity instead of visibility. However, the downside of this approach is that the parts remain selectable, which is not desired.
I don’t understand why setting opacity on an array of nodes works, but setting the visibility of the same array does not. I am using HOOPS 2024.5.0, and all my models were converted using the same version.
