The exchange plugin is not consistent in solid 2022 and 2020
Customer files he is the use of the 2020 version A3DAsmProductOccurrenceGetFilePathName unable to get to the correct path
first Image Missing the previous string of paths like ‘1234-name’ hoops viewer only shows ‘-name’
However, the 2022 solidworx export version can be displayed normally again。
This property of the second image shows the correct ‘xx-yy’
how can I solve the problem?
this is the second image
Hello @Ying.Li11,
Your first and second images highlight different nodes, so it is unclear what specific issue you are pointing out.
However, based on my best guess, the 2022 SolidWorks version appears to be correct. It’s possible that some sub-parts (.SLDPRT) were updated while the top assembly (.SLDASM) was not, which could explain the difference. Resaving the file in SolidWorks 2022 may have updated the information correctly. You might want to ask your customer to resave the file using the 2020 SolidWorks version to update the information correctly.
Best Regards,
Man
