Authorization tokens in Web Viewer
Hi, I have the following problem. Аpparently the web viewer has some underlying network request that it is executing. Right now I have a React application and I have a Hoops viewer component that has a cadData prop. cadData is a url where you can download a scs file. This is my comopnent:
type Props = {
  cadData: string;
const HoopsViewer = ({ cadData }: Props) => {
  useEffect(() => {
    script.onload = () => initViewer();
    return () => {
      hwv?.shutdown();
  const initViewer = () => {
      containerId: "viewer",
      endpointUri: cadData,
    console.log("hwvInstance", hwvInstance);
    try {
      hwvInstance.start();
      setHwv(hwvInstance);
      initNavCube(hwvInstance);
    } catch (error) {
  return (
      <div className="absolute bottom-10 left-1/2 transform -translate-x-1/2 flex items-center">
      </div>
    </div>
export default HoopsViewer;
All my requests to the server have an authorization token, but now I notice that apparently the viewer also executes a request that returns me a 401 and means that it does not apply the headers.
Is there a way to add authorization headers in the hoops web viewer? For example like this?
        // Hypothetical configuration to pass headers
        requestHeaders: {
            Authorization: `Bearer ${authToken}`
Hello @dayana,
The WebViewerConfig class has the property sessionToken. This might be what you are looking for.
Hi, @tino
Thank you for your reply. I have added the sessionToken to the web viewer config. But still I do not see the Authorization: Bearer ${token} in the headers of the request.
type Props = {
  cadData: string;
useEffect(() => {
    const loadViewer = async () => {
      const authToken = await currentSession();
      if (authToken) {
        initViewer(authToken);
      } else {
        console.error("Failed to retrieve auth token");
    script.onload = loadViewer;
    return () => {
      hwv?.shutdown();
  const initViewer = (authToken) => {
      // Token passed here
      sessionToken: `Bearer ${authToken}`
    try {
    } catch (error) {
  return (
      </div>
    </div>
Just to clarify the catData prop is actually a url for the control to go to and download the file, maybe this is a better example for you:
      endpointUri: `http://localhost:8000/source/demo-file.scs`,
      sessionToken: 'Token 12345',
Thanks for providing additional clarification, @dayana
So I don’t think sessionToken is going to help in this scenario. Additionally, the WebViewer class does not have a comparable parameter for requestHeaders: {"Authorization": Bearer ${authToken}.
Indeed a fetch command is used to retrieve the SCS file. The WebViewer class doesn’t have a direct parameter for the authorization token. I’m not 100% on this :crossed_fingers: – but I think you can try implementing a custom HTTP request (perhaps overriding the fetch function) that includes the necessary headers.
Hi @tino ,
Thanks for the quick reply. Yes, I would definitely like to try an override fetch. Do you have something in mind? Could you send me an example or at least the methods of this class bound to requests?
Best regards,
Dayana
With the help of ChatGPT for prototyping, this is one potential example (but your mileage may vary):
    // Intercept the original fetch function
    const originalFetch = window.fetch;
    // Override the fetch function to include authorization header
    window.fetch = (url, options) => {
        // If the URL matches the one you want to modify, add authorization header
        if (url === 'http://localhost:11180/myStreamCacheFile.scs') {
            options = options || {};
            options.headers = options.headers || new Headers();
            options.headers.append('Authorization', `Bearer ${authToken}`);
        // Call the original fetch function with modified options
        return originalFetch(url, options);
    // Initialize the WebViewer
        containerId: "myViewer",
        endpointUri: `http://localhost:11180/myStreamCacheFile.scs`,
    // Optionally, restore the original fetch function when done
    // window.fetch = originalFetch;
Hi, @tino
Thanks for the example, with a bit of processing on my part I was able to add the headers. However, overriding the fetch in this way should be careful as it may cause problems with other requests.
Best regards,
Dayana
