[Bug] SCS models render incompletely on Android devices in versions 2026.4.0+ (Works in 2026.1.0)
“I’m encountering an issue where models loaded from SCS files using the ts3d-hoops/web-viewer npm package are rendering partially or incompletely on most Android devices. However, the display works perfectly fine on PC and iPhone. I’ve tested versions 2026.4.0, 2026.5.0, and 2026.6.0, and the issue persists across all of them, whereas version 2026.1.0 works normally. How can I resolve this?”
For the Android devices in which the SCS rendering is failing, do you have more information on the make, model and OS? This can narrow our test case setup by finding a comparable Android device.
