The new Clash Manager library adds robust client and server-side clash detection capabilities to HOOPS Communicator, including support for both hard and soft (clearance) clashes and clash groups, among other features.
hello,Is there a plan to integrate it into hoops? I think at the moment it looks like this is a demo based on the web side。
I don’t know if it can be used in production or to guide simulations。thanx for your reply
hello. Looking at the attached video, it seems to work based on SCS model.
In the case of SC model (streaming model), the mesh is dynamically streamed depending on the camera distance. In this case, does the CLASH logic work even if the MESH is not streamed yet?
Thanks for this library. Is the library and the clash POC upgraded to the latest release of HOOPS Communicator and can you please share it with us?
I’m struggling to reproduce the following features of the current POC based on version 2023, namely clash between groups and clash while dragging, are not really working as demonstrated. May you please throw light on why & how to achieve that? Is there anything missing from the POC on the gitHub?
Thanks in advance,
With Best Regards,
Amol Khoje
That clash library has not been updated to the latest version of Communicator. Due to the open-source of GitHub, it is encouraged for proof-of-concept repos, that community members build upon the original repo.
There are notable changes in the API from v2023 to v2025. Namely, with the release of v2024.4.0, the Web Viewer follows the ESM standards.
When you say the group clash and clash while dragging are not working, are you getting specific API incompatibilities (errors) that you cannot resolve or is the functionality not consistent with the GitHub repo behavior?
Thanks for the context. We’re evaluating clash detection on Communicator 2025/26.
Can you confirm:
The last HC versionts3d-hc-clashmanager v0.7.4 was built/tested against?
Whether hcClashManager.min.js is expected to work with 2025/26 at all, or requires a new build from TS3D?
What you recommend for ESM integration—community fork of demo/server only, or is an updated npm package planned?
Whether server-side clash via ts3d-hc-imageservice is still viable on current Communicator.
We want to know if the GitHub POC is still a reasonable evaluation path for 2025/26, or only for older viewer versions.
For planning on Communicator 2025/26: will Tech Soft 3D ever publish the source for hcClashManager (or only updated minified builds)? If source stays closed, what is the supported path for API/ESM updates—official releases, partner access, or community-only maintenance of the GitHub wrapper?
