Cutting panels stop cutting when we select more than 1 cutting panel
Hi, do you have any idea why if I select for example two at the same time they both stop working. However, I noticed that if I select two panels and drag one to its opposite side, then the other one starts working. In the code functions for cutting panels are called addCuttingPlane, clearAllCuttingPlanes, handleCuttingPlaneChange. Thank you!
import { fetchAuthSession } from "aws-amplify/auth";
// import LayerTree from "./LayerTree";
import HomeIcon from "~/icons/HomeIcon";
import CameraIcon from "~/icons/CameraIcon";
import ExplodeCubeIcon from "~/icons/ExplodeCubeIcon";
import Select from 'react-select';
import Tooltip from "../basics/Tooltip";
const operatorOptions = [
  { value: 'Orbit', label: 'Orbit' },
  { value: 'Turntable', label: 'Turntable' }
const cameraPositions = {
  Front: { position: { x: 10, y: 0, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Back: { position: { x: -10, y: 0, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Right: { position: { x: 0, y: 10, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Left: { position: { x: 0, y: -10, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Top: { position: { x: 0, y: 0, z: 10 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 1, z: 1 } },
  Bottom: { position: { x: 0, y: 0, z: -10 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: -1, z: 1 } }
const cameraOptions = [
  { value: 'Front', label: 'Front View' },
  { value: 'Back', label: 'Back View' },
  { value: 'Right', label: 'Right View' },
  { value: 'Left', label: 'Left View' },
  { value: 'Top', label: 'Top View' },
  { value: 'Bottom', label: 'Bottom View' }
const cuttingPlaneOptions = [
  { value: 'X', label: 'X-axis' },
  { value: 'Y', label: 'Y-axis' },
  { value: 'Z', label: 'Z-axis' },
  { value: 'clearAll', label: 'Clear all' },
const drawModeOptions = [
    value: 'Shaded', label: "Shaded"
    value: 'HiddenLine', label: "Hidden Line"
    value: 'Wireframe', label: "Wireframe"
    value: 'XRay', label: "X Ray"
const buttonStyle = {
  backgroundColor: 'rgba(255, 255, 255, 0.50)',
  border: '1px solid rgba(156, 163, 175, 0.5)',
  borderRadius: '0.375rem',
  cursor: 'pointer',
  display: 'flex',
  alignItems: 'center',
  justifyContent: 'center',
  width: '40px',
  height: '40px'
type Props = {
  cadData: string;
const HoopsViewer = ({ cadData }: Props) => {
  const [explodeMagnitude, setExplodeMagnitude] = useState(0);
  const [showExplode, setShowExplode] = useState(false);
  const [drawMode, setDrawMode] = useState({ value: 'Shaded', label: "Shaded" });
  const [cameraView, setCameraView] = useState('Back');
  const [cuttingPlanes, setCuttingPlanes] = useState([]);
  const [selectsOpen, setSelectsOpen] = useState({
    operation: false,
    camera: false,
    drawMode: false,
    cuttingPlane: false
  const handleMenuOpen = (selectName) => {
    setSelectsOpen({ ...selectsOpen, [selectName]: true });
  const handleMenuClose = (selectName) => {
    setSelectsOpen({ ...selectsOpen, [selectName]: false });
  useEffect(() => {
    if (!cadData) {
      return;
    const initViewer = async () => {
      const session = await fetchAuthSession();
      const accessToken = session.tokens?.accessToken?.toString();
      if (!accessToken) {
        console.error("Error in HoopsViewer");
        return;
      if (hwv) {
        hwv.shutdown();
      initViewerWithCADData(accessToken, cadData);
    script.onload = () => {
      initViewer();
    return () => {
      if (hwv) {
        hwv.shutdown();
  }, [cadData]);
  const initViewerWithCADData = (authToken, cadData) => {
    const customFetch = (url, options = {}) => {
      if (url.includes(cadData)) {
        if (!(options.headers instanceof Headers)) {
          options.headers = new Headers(options.headers);
        options.headers.set('Authorization', `Bearer ${authToken}`);
      return originalFetch(url, options);
    if (!window.originalFetch) {
      window.originalFetch = window.fetch;
    window.fetch = customFetch;
      containerId: "viewer",
      endpointUri: cadData,
    hwvInstance.setCallbacks({
      sceneReady: function () {
        initAxisTriad(hwvInstance);
        initNavCube(hwvInstance);
    try {
      hwvInstance.start();
      setHwv(hwvInstance);
    } catch (error) {
  const initNavCube = (hwvInstance) => {
    const navCube = hwvInstance.view.getNavCube();
    navCube.setAnchor(window.Communicator.OverlayAnchor.UpperRightCorner);
    navCube.enable();
  const initAxisTriad = (hwvInstance) => {
    const axisTriad = hwvInstance.view.getAxisTriad();
    axisTriad.setAnchor(window.Communicator.OverlayAnchor.LowerLeftCorner);
    axisTriad.setAxisColor(Communicator.Axis.Y, Communicator.Color.blue());
    axisTriad.setAxisColor(Communicator.Axis.X, Communicator.Color.green());
    axisTriad.setAxisColor(Communicator.Axis.Z, Communicator.Color.red());
    axisTriad.enable();
  const addCuttingPlane = async (type) => {
    if (!hwv || cuttingPlanes.length >= 6) return;
    try {
      const bounding = await hwv.model.getModelBounding(true, true);
      let axis, normal, position;
      switch (type) {
        case 'X':
          axis = Communicator.Axis.X;
          normal = new Communicator.Point3(1, 0, 0);
          position = bounding.max;
          break;
        case 'Y':
          axis = Communicator.Axis.Y;
          normal = new Communicator.Point3(0, 1, 0);
          break;
        case 'Z':
          axis = Communicator.Axis.Z;
          normal = new Communicator.Point3(0, 0, 1);
          break;
        default:
          console.error("Invalid plane type selected");
          return;
      const referenceGeometry = hwv.cuttingManager.createReferenceGeometryFromAxis(axis, bounding);
      const plane = Communicator.Plane.createFromPointAndNormal(position, normal);
      const cuttingSection = hwv.cuttingManager.getCuttingSection(0);
      await cuttingSection.addPlane(plane, referenceGeometry);
      await cuttingSection.activate();
      setCuttingPlanes([...cuttingPlanes, { type, plane }]);
    } catch (error) {
      console.error("Error adding cutting plane:", error);
  const clearAllCuttingPlanes = async () => {
    if (!hwv) {
      console.error("HWV instance not initialized");
      return;
    try {
      await hwv.cuttingManager.clearAllCuttingSections();
      console.log("All cutting sections cleared and deactivated.");
      setCuttingPlanes([]);
    } catch (error) {
      console.error("Error clearing cutting sections:", error);
  const handleCuttingPlaneChange = (selectedOption) => {
    switch (selectedOption.value) {
      case 'clearAll':
        clearAllCuttingPlanes();
        break;
      default:
        addCuttingPlane(selectedOption.value);
        break;
  const resetCamera = () => {
    hwv.view.resetCamera(750);
  const handleChangeDrawMode = (selectedOption) => {
    setDrawMode(selectedOption);
    hwv.view.setDrawMode(Communicator.DrawMode[selectedOption.value]);
  const handleChangeCameraView = (selectedOption) => {
    setCameraView(selectedOption.value);
    const config = cameraPositions[selectedOption.value];
    const newCamera = new Communicator.Camera();
    hwv.model.getModelBounding(true, true).then((bounding) => {
      const center = new Communicator.Point3(
        (bounding.min.x + bounding.max.x) / 2,
        (bounding.min.y + bounding.max.y) / 2,
        (bounding.min.z + bounding.max.z) / 2
      newCamera.setPosition(new Communicator.Point3(
        config.position.x + center.x - config.target.x,
        config.position.y + center.y - config.target.y,
        config.position.z + center.z - config.target.z
      newCamera.setTarget(center);
      newCamera.setUp(new Communicator.Point3(config.up.x, config.up.y, config.up.z));
      const size = Math.sqrt(
        Math.pow(bounding.max.x - bounding.min.x, 2) +
        Math.pow(bounding.max.y - bounding.min.y, 2) +
        Math.pow(bounding.max.z - bounding.min.z, 2)
      const aspectRatio = hwv.view.getCanvasSize().x / hwv.view.getCanvasSize().y;
      const zoomFactor = 0.75;
      const fieldOfView = zoomFactor * size;
      newCamera.setWidth(fieldOfView * aspectRatio);
      newCamera.setHeight(fieldOfView);
      hwv.view.setCamera(newCamera, 750);
    }).catch((error) => {
      console.error("Error setting camera view:", error);
  const handleChangeExplodeMagnitude = (event) => {
    const newMagnitude = Number(event.target.value);
    setExplodeMagnitude(newMagnitude);
    if (hwv) {
      hwv.getExplodeManager().setMagnitude(newMagnitude / 100);
  const createSnapshotConfig = () => {
    const config = new Communicator.SnapshotConfig();
    config.width = 1920;
    config.height = 1080;
    config.layers = Communicator.SnapshotLayer.All;
    return config;
  const takeSnapshot = () => {
    if (!hwv) {
      return;
    const snapshotConfig = createSnapshotConfig();
    hwv.takeSnapshot(snapshotConfig).then((result) => {
      if (result instanceof Blob) {
        const url = URL.createObjectURL(result);
        const link = document.createElement('a');
        link.href = url;
        link.download = "snapshot.png";
        link.click();
        URL.revokeObjectURL(url);
      } else if (result instanceof HTMLImageElement) {
        const src = result.src;
        link.href = src;
        link.click();
      } else {
        console.error("Snapshot did not return a valid result:", result);
      console.error("Error taking snapshot:", error);
  const handleOperationChange = (selectedOption) => {
    if (!hwv) {
      return;
    const operatorManager = hwv.operatorManager;
    let operatorId;
      case 'Orbit':
        operatorId = Communicator.OperatorId.Orbit;
        break;
      case 'Turntable':
        operatorId = Communicator.OperatorId.Turntable;
        break;
      default:
        console.error("Unsupported operation:", selectedOption.value);
        return;
    if (operatorId !== undefined) {
      operatorManager.set(operatorId, 0);
    } else {
      console.error("Invalid operator ID for", selectedOption.value);
  return (
      <div className="absolute bottom-12 left-1/2 transform -translate-x-1/2 flex items-center">
        <Tooltip text={"Reset camera"} position="top">
          <div style={{ ...buttonStyle, marginRight: '10px' }} onClick={resetCamera}>
            <HomeIcon className="w-4 h-4 text-black" />
          </div>
        </Tooltip>
        <Tooltip text="Take Snapshot" position="top">
          <div style={{ ...buttonStyle }} onClick={takeSnapshot}>
            <CameraIcon className="w-4 h-4" />
          </div>
        </Tooltip>
        <Tooltip text="Camera Operation" position="top" isVisible={!selectsOpen?.operation}>
          <Select
            placeholder="Ca.."
            onChange={handleOperationChange}
            options={operatorOptions}
            onMenuOpen={() => handleMenuOpen('operation')}
            onMenuClose={() => handleMenuClose('operation')}
            menuPlacement="top"
            styles={{
              control: (base) => ({
                ...base,
                minWidth: 80,
                marginLeft: "10px",
                cursor: "pointer",
                marginRight: "10px",
                borderColor: 'rgba(156, 163, 175, 0.5)',
                boxShadow: 'none',
                zIndex: 1000,
                '&:hover': {
        </Tooltip>
        <Tooltip text="Camera menu" position="top" isVisible={!selectsOpen.camera}>
          <Select
            value={cameraOptions.find(option => option.value === cameraView)}
            onChange={handleChangeCameraView}
            options={cameraOptions}
            onMenuOpen={() => handleMenuOpen('camera')}
            onMenuClose={() => handleMenuClose('camera')}
            menuPlacement="top"
            styles={{
                ...base,
                cursor: "pointer",
                minWidth: 80,
                boxShadow: 'none',
                '&:hover': {
                zIndex: 1000
        </Tooltip>
        <Tooltip text="Draw mode" position="top" isVisible={!selectsOpen.drawMode}>
          <Select
            value={drawMode}
            onChange={handleChangeDrawMode}
            options={drawModeOptions}
            onMenuOpen={() => handleMenuOpen('drawMode')}
            onMenuClose={() => handleMenuClose('drawMode')}
            menuPlacement="top"
            styles={{
                ...base,
                minWidth: 80,
                cursor: "pointer",
                boxShadow: 'none',
                '&:hover': {
                zIndex: 1000
        </Tooltip>
        <Tooltip text="Explode Menu" position="top" isVisible={!showExplode}>
          <div style={{ ...buttonStyle, position: 'relative', marginRight: "10px" }} onClick={() => setShowExplode(!showExplode)}>
            <ExplodeCubeIcon className="w-4 h-4" />
            {showExplode && (
              <input
                type="range"
                min="0"
                max="100"
                value={explodeMagnitude}
                onChange={handleChangeExplodeMagnitude}
                className="slider-vertical"
          </div>
        </Tooltip>
        <Tooltip text="Cutting Plane Menu" position="top" isVisible={!selectsOpen?.cuttingPlane}>
          <Select
            placeholder="Cu.."
            onChange={handleCuttingPlaneChange}
            options={cuttingPlaneOptions}
            onMenuOpen={() => handleMenuOpen('cuttingPlane')}
            onMenuClose={() => handleMenuClose('cuttingPlane')}
            menuPlacement="top"
            styles={{
                ...base,
                minWidth: 80,
                cursor: "pointer",
                boxShadow: 'none',
                zIndex: 100,
                '&:hover': {
        </Tooltip>
      </div>
      {/* {hwv && <LayerTree hwv={hwv} />} */}
    </div>
export default HoopsViewer;
Hello @dayana,
A single cutting section can have muliple cutting planes. The planes in a section are designed to work together to achieve a cross-section view of the model. So if one plane is otherwise off to the side and not cutting/culling anything, it can look like the other cutting plane is essentially deactivated.
It sounds like what you want is the cutting planes to be independent of each other. To that end, our recommendation is to create multiple cutting sections for EACH plane, for example:
const cuttingSection0 = hwv.cuttingManager.getCuttingSection(0);
const cuttingSection1 = hwv.cuttingManager.getCuttingSection(1);
You will also need to adjust accordingly for the new additional plane and referenceGeometry objects. So something like this:
cuttingSection0.addPlane(plane0, referenceGeometry0);
cuttingSection1.addPlane(plane1, referenceGeometry1);
await cuttingSection0.activate();
await cuttingSection1.activate();
Thank you @tino, now it works as expected.
