Zoom and Pan stop working when changing orbit camera
Hello, in principle I have the option in my React component to change the orbit camera to orbit and turntable. Initially I use an orbit camera and then I have the options to zoom with the mouse and use pan and walk around the object. However, when I change to turntable and then back to orbit camera this functionality is lost, can you help me. The functions responsible for this are called handleOperationChange. Thanks in advance!
import { fetchAuthSession } from "aws-amplify/auth";
// import LayerTree from "./LayerTree";
import HomeIcon from "~/icons/HomeIcon";
import CameraIcon from "~/icons/CameraIcon";
import ExplodeCubeIcon from "~/icons/ExplodeCubeIcon";
import Select from 'react-select';
import Tooltip from "../basics/Tooltip";
const operatorOptions = [
  { value: 'Orbit', label: 'Orbit' },
  { value: 'Turntable', label: 'Turntable' }
const cameraPositions = {
  Front: { position: { x: 10, y: 0, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Back: { position: { x: -10, y: 0, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Right: { position: { x: 0, y: 10, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Left: { position: { x: 0, y: -10, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Top: { position: { x: 0, y: 0, z: 10 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 1, z: 1 } },
  Bottom: { position: { x: 0, y: 0, z: -10 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: -1, z: 1 } }
const cameraOptions = [
  { value: 'Front', label: 'Front View' },
  { value: 'Back', label: 'Back View' },
  { value: 'Right', label: 'Right View' },
  { value: 'Left', label: 'Left View' },
  { value: 'Top', label: 'Top View' },
  { value: 'Bottom', label: 'Bottom View' }
const cuttingPlaneOptions = [
  { value: 'X', label: 'X-axis' },
  { value: 'Y', label: 'Y-axis' },
  { value: 'Z', label: 'Z-axis' },
  { value: 'clearAll', label: 'Clear all' },
const drawModeOptions = [
    value: 'Shaded', label: "Shaded"
    value: 'HiddenLine', label: "Hidden Line"
    value: 'Wireframe', label: "Wireframe"
    value: 'XRay', label: "X Ray"
const buttonStyle = {
  backgroundColor: 'rgba(255, 255, 255, 0.50)',
  border: '1px solid rgba(156, 163, 175, 0.5)',
  borderRadius: '0.375rem',
  cursor: 'pointer',
  display: 'flex',
  alignItems: 'center',
  justifyContent: 'center',
  width: '40px',
  height: '40px'
type Props = {
  cadData: string;
const HoopsViewer = ({ cadData }: Props) => {
  const [explodeMagnitude, setExplodeMagnitude] = useState(0);
  const [showExplode, setShowExplode] = useState(false);
  const [drawMode, setDrawMode] = useState({ value: 'Shaded', label: "Shaded" });
  const [cameraView, setCameraView] = useState('Back');
  const [cuttingPlanes, setCuttingPlanes] = useState([]);
  const [selectsOpen, setSelectsOpen] = useState({
    operation: false,
    camera: false,
    drawMode: false,
    cuttingPlane: false
  const handleMenuOpen = (selectName) => {
    setSelectsOpen({ ...selectsOpen, [selectName]: true });
  const handleMenuClose = (selectName) => {
    setSelectsOpen({ ...selectsOpen, [selectName]: false });
  useEffect(() => {
    if (!cadData) {
      return;
    const initViewer = async () => {
      const session = await fetchAuthSession();
      const accessToken = session.tokens?.accessToken?.toString();
      if (!accessToken) {
        console.error("Error in HoopsViewer");
        return;
      if (hwv) {
        hwv.shutdown();
      initViewerWithCADData(accessToken, cadData);
    script.onload = () => {
      initViewer();
    return () => {
      if (hwv) {
        hwv.shutdown();
  }, [cadData]);
  const initViewerWithCADData = (authToken, cadData) => {
    const customFetch = (url, options = {}) => {
      if (url.includes(cadData)) {
        if (!(options.headers instanceof Headers)) {
          options.headers = new Headers(options.headers);
        options.headers.set('Authorization', `Bearer ${authToken}`);
      return originalFetch(url, options);
    if (!window.originalFetch) {
      window.originalFetch = window.fetch;
    window.fetch = customFetch;
      containerId: "viewer",
      endpointUri: cadData,
    hwvInstance.setCallbacks({
      sceneReady: function () {
        initAxisTriad(hwvInstance);
        initNavCube(hwvInstance);
    try {
      hwvInstance.start();
      setHwv(hwvInstance);
    } catch (error) {
  const initNavCube = (hwvInstance) => {
    const navCube = hwvInstance.view.getNavCube();
    navCube.setAnchor(window.Communicator.OverlayAnchor.UpperRightCorner);
    navCube.enable();
  const initAxisTriad = (hwvInstance) => {
    const axisTriad = hwvInstance.view.getAxisTriad();
    axisTriad.setAnchor(window.Communicator.OverlayAnchor.LowerLeftCorner);
    axisTriad.setAxisColor(Communicator.Axis.Y, Communicator.Color.blue());
    axisTriad.setAxisColor(Communicator.Axis.X, Communicator.Color.green());
    axisTriad.setAxisColor(Communicator.Axis.Z, Communicator.Color.red());
    axisTriad.enable();
  const addCuttingPlane = async (type) => {
    if (!hwv || cuttingPlanes.length >= 6) return;
    try {
      const bounding = await hwv.model.getModelBounding(true, true);
      let axis, normal, position;
      switch (type) {
        case 'X':
          axis = Communicator.Axis.X;
          normal = new Communicator.Point3(1, 0, 0);
          position = bounding.max;
          break;
        case 'Y':
          axis = Communicator.Axis.Y;
          normal = new Communicator.Point3(0, 1, 0);
          break;
        case 'Z':
          axis = Communicator.Axis.Z;
          normal = new Communicator.Point3(0, 0, 1);
          break;
        default:
          console.error("Invalid plane type selected");
          return;
      const referenceGeometry = hwv.cuttingManager.createReferenceGeometryFromAxis(axis, bounding);
      const plane = Communicator.Plane.createFromPointAndNormal(position, normal);
      const cuttingSection = hwv.cuttingManager.getCuttingSection(0);
      await cuttingSection.addPlane(plane, referenceGeometry);
      await cuttingSection.activate();
      setCuttingPlanes([...cuttingPlanes, { type, plane }]);
    } catch (error) {
      console.error("Error adding cutting plane:", error);
  const clearAllCuttingPlanes = async () => {
    if (!hwv) {
      console.error("HWV instance not initialized");
      return;
    try {
      await hwv.cuttingManager.clearAllCuttingSections();
      console.log("All cutting sections cleared and deactivated.");
      setCuttingPlanes([]);
    } catch (error) {
      console.error("Error clearing cutting sections:", error);
  const handleCuttingPlaneChange = (selectedOption) => {
    switch (selectedOption.value) {
      case 'clearAll':
        clearAllCuttingPlanes();
        break;
      default:
        addCuttingPlane(selectedOption.value);
        break;
  const resetCamera = () => {
    hwv.view.resetCamera(750);
  const handleChangeDrawMode = (selectedOption) => {
    setDrawMode(selectedOption);
    hwv.view.setDrawMode(Communicator.DrawMode[selectedOption.value]);
  const handleChangeCameraView = (selectedOption) => {
    setCameraView(selectedOption.value);
    const config = cameraPositions[selectedOption.value];
    const newCamera = new Communicator.Camera();
    hwv.model.getModelBounding(true, true).then((bounding) => {
      const center = new Communicator.Point3(
        (bounding.min.x + bounding.max.x) / 2,
        (bounding.min.y + bounding.max.y) / 2,
        (bounding.min.z + bounding.max.z) / 2
      newCamera.setPosition(new Communicator.Point3(
        config.position.x + center.x - config.target.x,
        config.position.y + center.y - config.target.y,
        config.position.z + center.z - config.target.z
      newCamera.setTarget(center);
      newCamera.setUp(new Communicator.Point3(config.up.x, config.up.y, config.up.z));
      const size = Math.sqrt(
        Math.pow(bounding.max.x - bounding.min.x, 2) +
        Math.pow(bounding.max.y - bounding.min.y, 2) +
        Math.pow(bounding.max.z - bounding.min.z, 2)
      const aspectRatio = hwv.view.getCanvasSize().x / hwv.view.getCanvasSize().y;
      const zoomFactor = 0.75;
      const fieldOfView = zoomFactor * size;
      newCamera.setWidth(fieldOfView * aspectRatio);
      newCamera.setHeight(fieldOfView);
      hwv.view.setCamera(newCamera, 750);
    }).catch((error) => {
      console.error("Error setting camera view:", error);
  const handleChangeExplodeMagnitude = (event) => {
    const newMagnitude = Number(event.target.value);
    setExplodeMagnitude(newMagnitude);
    if (hwv) {
      hwv.getExplodeManager().setMagnitude(newMagnitude / 100);
  const createSnapshotConfig = () => {
    const config = new Communicator.SnapshotConfig();
    config.width = 1920;
    config.height = 1080;
    config.layers = Communicator.SnapshotLayer.All;
    return config;
  const takeSnapshot = () => {
    if (!hwv) {
      return;
    const snapshotConfig = createSnapshotConfig();
    hwv.takeSnapshot(snapshotConfig).then((result) => {
      if (result instanceof Blob) {
        const url = URL.createObjectURL(result);
        const link = document.createElement('a');
        link.href = url;
        link.download = "snapshot.png";
        link.click();
        URL.revokeObjectURL(url);
      } else if (result instanceof HTMLImageElement) {
        const src = result.src;
        link.href = src;
        link.click();
      } else {
        console.error("Snapshot did not return a valid result:", result);
      console.error("Error taking snapshot:", error);
  const handleOperationChange = (selectedOption) => {
    if (!hwv) {
      return;
    const operatorManager = hwv.operatorManager;
    let operatorId;
      case 'Orbit':
        operatorId = Communicator.OperatorId.Orbit;
        break;
      case 'Turntable':
        operatorId = Communicator.OperatorId.Turntable;
        break;
      default:
        console.error("Unsupported operation:", selectedOption.value);
        return;
    if (operatorId !== undefined) {
      operatorManager.set(operatorId, 0);
    } else {
      console.error("Invalid operator ID for", selectedOption.value);
  return (
      <div className="absolute bottom-12 left-1/2 transform -translate-x-1/2 flex items-center">
        <Tooltip text={"Reset camera"} position="top">
          <div style={{ ...buttonStyle, marginRight: '10px' }} onClick={resetCamera}>
            <HomeIcon className="w-4 h-4 text-black" />
          </div>
        </Tooltip>
        <Tooltip text="Take Snapshot" position="top">
          <div style={{ ...buttonStyle }} onClick={takeSnapshot}>
            <CameraIcon className="w-4 h-4" />
          </div>
        </Tooltip>
        <Tooltip text="Camera Operation" position="top" isVisible={!selectsOpen?.operation}>
          <Select
            placeholder="Ca.."
            onChange={handleOperationChange}
            options={operatorOptions}
            onMenuOpen={() => handleMenuOpen('operation')}
            onMenuClose={() => handleMenuClose('operation')}
            menuPlacement="top"
            styles={{
              control: (base) => ({
                ...base,
                minWidth: 80,
                marginLeft: "10px",
                cursor: "pointer",
                marginRight: "10px",
                borderColor: 'rgba(156, 163, 175, 0.5)',
                boxShadow: 'none',
                zIndex: 1000,
                '&:hover': {
        </Tooltip>
        <Tooltip text="Camera menu" position="top" isVisible={!selectsOpen.camera}>
          <Select
            value={cameraOptions.find(option => option.value === cameraView)}
            onChange={handleChangeCameraView}
            options={cameraOptions}
            onMenuOpen={() => handleMenuOpen('camera')}
            onMenuClose={() => handleMenuClose('camera')}
            menuPlacement="top"
            styles={{
                ...base,
                cursor: "pointer",
                minWidth: 80,
                boxShadow: 'none',
                '&:hover': {
                zIndex: 1000
        </Tooltip>
        <Tooltip text="Draw mode" position="top" isVisible={!selectsOpen.drawMode}>
          <Select
            value={drawMode}
            onChange={handleChangeDrawMode}
            options={drawModeOptions}
            onMenuOpen={() => handleMenuOpen('drawMode')}
            onMenuClose={() => handleMenuClose('drawMode')}
            menuPlacement="top"
            styles={{
                ...base,
                minWidth: 80,
                cursor: "pointer",
                boxShadow: 'none',
                '&:hover': {
                zIndex: 1000
        </Tooltip>
        <Tooltip text="Explode Menu" position="top" isVisible={!showExplode}>
          <div style={{ ...buttonStyle, position: 'relative', marginRight: "10px" }} onClick={() => setShowExplode(!showExplode)}>
            <ExplodeCubeIcon className="w-4 h-4" />
            {showExplode && (
              <input
                type="range"
                min="0"
                max="100"
                value={explodeMagnitude}
                onChange={handleChangeExplodeMagnitude}
                className="slider-vertical"
          </div>
        </Tooltip>
        <Tooltip text="Cutting Plane Menu" position="top" isVisible={!selectsOpen?.cuttingPlane}>
          <Select
            placeholder="Cu.."
            onChange={handleCuttingPlaneChange}
            options={cuttingPlaneOptions}
            onMenuOpen={() => handleMenuOpen('cuttingPlane')}
            onMenuClose={() => handleMenuClose('cuttingPlane')}
            menuPlacement="top"
            styles={{
                ...base,
                minWidth: 80,
                cursor: "pointer",
                boxShadow: 'none',
                zIndex: 100,
                '&:hover': {
        </Tooltip>
      </div>
      {/* {hwv && <LayerTree hwv={hwv} />} */}
    </div>
export default HoopsViewer;
Hello @dayana,
In your code, you are using Communicator.OperatorId.Orbit which is different from Communicator.OperatorId.Navigate. The latter operator combines pan, zoom and orbit. Whereas the former is only orbit.
By default, Communicator.OperatorId.Navigate is enabled which is why, in the beginning, you are able to use pan as well. Now, when you start toggling between Orbit and Turntable, Navigate “gets lost in the shuffle.” All this is to say that what you should be using is Navigate instead of Orbit to preserve panning and zooming:
case 'Orbit':
        operatorId = Communicator.OperatorId.Navigate;
        break;
If you do want Orbit as a standalone operator, you will have to include Navigate as another option.
Thanks again @tino !
Best regards,
Dayana
