Problem implementing orbit camera and turntable in React.js
Оne of the next problems I encountered is implementing orbit camera, and turntable. I was trying to follow the following pages:
[OperatorId — HOOPS Communicator 2024.2.0 Documentation]
[OperatorManager — HOOPS Communicator 2024.2.0 Documentation]
Here is an example implementation(reffer to handleOperationChange):
import LayerTree from "./LayerTree";
import HomeIcon from "~/icons/HomeIcon";
import ExplodeCubeIcon from "~/icons/ExplodeCubeIcon";
import Select from 'react-select';
import Tooltip from "../basics/Tooltip";
const operatorOptions = [
  { value: 'Orbit', label: 'Orbit' },
  { value: 'Turntable', label: 'Turntable' }
const cameraPositions = {
  Front: { position: { x: 10, y: 0, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Back: { position: { x: -10, y: 0, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Right: { position: { x: 0, y: 10, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Left: { position: { x: 0, y: -10, z: 0 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 0, z: 1 } },
  Top: { position: { x: 0, y: 0, z: 10 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: 1, z: 1 } },
  Bottom: { position: { x: 0, y: 0, z: -10 }, target: { x: 0, y: 0, z: 0 }, up: { x: 0, y: -1, z: 1 } }
const cameraOptions = [
  { value: 'Front', label: 'Front View' },
  { value: 'Back', label: 'Back View' },
  { value: 'Right', label: 'Right View' },
  { value: 'Left', label: 'Left View' },
  { value: 'Top', label: 'Top View' },
  { value: 'Bottom', label: 'Bottom View' }
const cuttingPlaneOptions = [
  { value: 'X', label: 'X-axis' },
  { value: 'Y', label: 'Y-axis' },
  { value: 'Z', label: 'Z-axis' },
  { value: 'FaceNormal', label: 'Face Normal' }
const drawModeOptions = [
    value: 'Shaded', label: "Shaded"
    value: 'HiddenLine', label: "Hidden Line"
    value: 'Wireframe', label: "Wireframe"
    value: 'XRay', label: "X Ray"
const buttonStyle = {
  backgroundColor: 'rgba(255, 255, 255, 0.50)',
  border: '1px solid rgba(156, 163, 175, 0.5)',
  borderRadius: '0.375rem',
  cursor: 'pointer',
  display: 'flex',
  alignItems: 'center',
  justifyContent: 'center',
  width: '40px',
  height: '40px'
const HoopsViewer = () => {
  const [explodeMagnitude, setExplodeMagnitude] = useState(0);
  const [showExplode, setShowExplode] = useState(false);
  const [drawMode, setDrawMode] = useState({ value: 'Shaded', label: "Shaded" });
  const [cameraView, setCameraView] = useState('Back');
  const [cuttingPlanes, setCuttingPlanes] = useState([]);
  useEffect(() => {
    script.onload = () => initViewer();
    return () => {
      hwv?.shutdown();
  const initViewer = () => {
      containerId: "viewer",
      endpointUri: "/data/microengine.scs",
    try {
      hwvInstance.start();
      setHwv(hwvInstance);
      initNavCube(hwvInstance);
    } catch (error) {
  const initNavCube = (hwvInstance) => {
    const navCube = hwvInstance.view.getNavCube();
    navCube.setAnchor(window.Communicator.OverlayAnchor.TopRight);
    navCube.enable();
  const addCuttingPlane = async (type) => {
    if (!hwv || cuttingPlanes.length >= 6) return;
    try {
      const bounding = await hwv.model.getModelBounding(true, true);
      let axis, normal, position;
      switch (type) {
        case 'X':
          axis = Communicator.Axis.X;
          normal = new Communicator.Point3(1, 0, 0);
          position = bounding.min;
          break;
        case 'Y':
          axis = Communicator.Axis.Y;
          normal = new Communicator.Point3(0, 1, 0);
          break;
        case 'Z':
          axis = Communicator.Axis.Z;
          normal = new Communicator.Point3(0, 0, 1);
          break;
        case 'FaceNormal':
          position = bounding.center();
          break;
        default:
          console.error("Invalid plane type selected");
          return;
      const referenceGeometry = hwv.cuttingManager.createReferenceGeometryFromAxis(Communicator.Axis.X, bounding);
      const plane = Communicator.Plane.createFromPointAndNormal(position, normal);
      const cuttingSection = hwv.cuttingManager.getCuttingSection(0);
      await cuttingSection.addPlane(plane, referenceGeometry);
      await cuttingSection.activate();
      setCuttingPlanes([...cuttingPlanes, { type, plane }]);
    } catch (error) {
      console.error("Error adding cutting plane:", error);
  const handleCuttingPlaneChange = (selectedOption) => {
    addCuttingPlane(selectedOption.value);
  const resetCamera = () => {
    hwv.view.resetCamera(750);
  const handleChangeDrawMode = (selectedOption) => {
    setDrawMode(selectedOption);
    hwv.view.setDrawMode(Communicator.DrawMode[selectedOption.value]);
  const handleChangeCameraView = (selectedOption) => {
    setCameraView(selectedOption.value);
    const config = cameraPositions[selectedOption.value];
    const newCamera = new Communicator.Camera();
    newCamera.setPosition(new Communicator.Point3(config.position.x, config.position.y, config.position.z));
    newCamera.setTarget(new Communicator.Point3(config.target.x, config.target.y, config.target.z));
    newCamera.setUp(new Communicator.Point3(config.up.x, config.up.y, config.up.z));
    const aspectRatio = hwv.view.getCanvasSize().x / hwv.view.getCanvasSize().y;
    const baseSize = 200;
    newCamera.setWidth(baseSize * aspectRatio);
    newCamera.setHeight(baseSize);
    hwv.view.setCamera(newCamera, 750);
  const handleChangeExplodeMagnitude = (event) => {
    const newMagnitude = Number(event.target.value);
    setExplodeMagnitude(newMagnitude);
    if (hwv) {
      hwv.getExplodeManager().setMagnitude(newMagnitude / 100);
  const createSnapshotConfig = () => {
    const config = new Communicator.SnapshotConfig();
    config.width = 1920;
    config.height = 1080;
    config.layers = Communicator.SnapshotLayer.All;
    return config;
  const takeSnapshot = () => {
    if (!hwv) {
      console.error("HWV instance not initialized");
      return;
    const snapshotConfig = createSnapshotConfig();
    hwv.takeSnapshot(snapshotConfig).then((result) => {
      if (result instanceof Blob) {
        const url = URL.createObjectURL(result);
        const link = document.createElement('a');
        link.href = url;
        link.download = "snapshot.png";
        link.click();
        URL.revokeObjectURL(url);
      } else if (result instanceof HTMLImageElement) {
        const src = result.src;
        link.href = src;
        link.click();
      } else {
        console.error("Snapshot did not return a valid result:", result);
    }).catch((error) => {
      console.error("Error taking snapshot:", error);
  const handleOperationChange = (selectedOption) => {
    if (!hwv) {
      return;
    const operatorManager = hwv.operatorManager;
    operatorManager.pop();
    let operatorId;
    switch (selectedOption.value) {
      case 'Orbit':
        operatorId = Communicator.OperatorId.Orbit;
        break;
      case 'Turntable':
        operatorId = Communicator.OperatorId.Turntable;
        break;
      default:
        console.error("Unsupported operation:", selectedOption.value);
        return;
    if (operatorId !== undefined) {
      operatorManager.push(operatorId);
    } else {
      console.error("Invalid operator ID for", selectedOption.value);
  return (
      <div className="absolute bottom-10 left-1/2 transform -translate-x-1/2 flex items-center">
        <Tooltip text={"Reset camera"} position="left">
          <div style={{ ...buttonStyle, marginRight: '10px' }} onClick={resetCamera}>
            <HomeIcon className="w-4 h-4 text-black" />
          </div>
        </Tooltip>
        <Tooltip text="Take Snapshot" position="left">
          <div style={{ ...buttonStyle }} onClick={takeSnapshot}>
            <span>📸</span>
          </div>
        </Tooltip>
        <Tooltip text="Camera Operation" position="left">
          <Select
            placeholder="Ca.."
            onChange={handleOperationChange}
            options={operatorOptions}
            menuPlacement="top"
            styles={{
              control: (base) => ({
                ...base,
                minWidth: 80,
                marginLeft: "10px",
                cursor: "pointer",
                marginRight: "10px",
                borderColor: 'rgba(156, 163, 175, 0.5)',
                boxShadow: 'none',
                '&:hover': {
        </Tooltip>
        <Tooltip text="Camera menu" position="left">
          <Select
            value={cameraOptions.find(option => option.value === cameraView)}
            onChange={handleChangeCameraView}
            options={cameraOptions}
            menuPlacement="top"
            styles={{
                ...base,
                cursor: "pointer",
                marginLeft: "10px",
                minWidth: 80,
                boxShadow: 'none',
                '&:hover': {
        </Tooltip>
        <Tooltip text="Draw mode" position="left">
          <Select
            value={drawMode}
            onChange={handleChangeDrawMode}
            options={drawModeOptions}
            menuPlacement="top"
            styles={{
                ...base,
                minWidth: 80,
                cursor: "pointer",
                boxShadow: 'none',
                '&:hover': {
        </Tooltip>
        <Tooltip text="Explode Menu" position="left">
          <div style={{ ...buttonStyle, position: 'relative', marginRight: "10px" }} onClick={() => setShowExplode(!showExplode)}>
            <ExplodeCubeIcon className="w-4 h-4" />
            {showExplode && (
              <input
                type="range"
                min="0"
                max="100"
                value={explodeMagnitude}
                onChange={handleChangeExplodeMagnitude}
                className="slider-vertical"
          </div>
        </Tooltip>
        <Tooltip text="Cutting Plane Menu" position="left">
          <Select
            placeholder="Cu.."
            onChange={handleCuttingPlaneChange}
            options={cuttingPlaneOptions}
            menuPlacement="top"
            styles={{
                ...base,
                minWidth: 80,
                cursor: "pointer",
                boxShadow: 'none',
                '&:hover': {
        </Tooltip>
      </div>
      {hwv && <LayerTree hwv={hwv} />}
    </div>
export default HoopsViewer;
When I selectt ‘Orbit’ for example the camera is breaking, and when I select ‘Turntable’ camera mode is not changing at all. Any advice will be very helpfull for me. Thank you in advance !
Hello @dayana,
By default, the operator stack will have its own set of operators already in the stack. Of note among these operators is CameraNavigationOperator – which is at the bottom of the stack. As mentioned in our docs, it is not recommended to push an operator to the top of stack as this could interfere with “similar” operators already in the stack. In this case, Navigate and Orbit are both camera-related operators.
Rather than calling pop, you can try calling set to replace Navigate with Orbit:
operatorManager.set(operatorId, 0);
This should also work with Turntable.
Hello, @tino
Thank you for providing me this solution! It works now as expected. Thank you !
Best regards,
Dayana
