Edit the "setup.ini" to install AutoCAD 2024 OEM
Hello.
want to install the german version of AutoCAD 2024 OEM.
In the instructions for the VBA overlay there is an entry called (I have copied the VBA overlay files before):
Add “VBA71;VBA71ENU;VBA71LANG” to the ‘PREREQUISITE’ variable in the [AOEM] section of C:\Autodesk\Autodesk_OEM_2024_Win_64_Bit\setup.ini.
But in the setup.ini there is no [AOEM] section.
Should I make a whole entry?
[AOEM]
Prerequisite = VBA71;VBA71ENU;VBA71LANG
Thanks for your help
Stefan
Stefan,
Did you find an answer for this?
Shawn
Microvellum
I only added the [OEM] section to the ini-file and it seems to work. I don’t know if this is really necessary or it might work without the add.
Thanks for sharing your solution!
