Someone recently asked: Is it possible to extract the physical properties (surface area and volume) during the conversion process via the command line interface?
Answer: Yes, it is possible to extract the physical properties using converter.exe’s command line interface. Use the --output_xml_assemblytree command line option to set an xml file that you can parse. The physical properties for each node will be included.
