HOOPS Communicator Converter convert CAD models using HOOPS Exchange with Exchange API Read/Write parameters which are exposed to Converter command line options.
Here is a list of command line options and corresponded parameters of HOOPS Exchnage.
| –configuration |
A3DRWParamsMultiEntriesData::m_ppcEntries |
| –drawings_mode |
A3DRWParamsGeneralData::m_eReadingMode2D3D |
| –import_hidden_objects |
A3DRWParamsGeneralData::m_bReadHiddenObjects |
| –import_pmi |
A3DRWParamsGeneralData::m_bReadPmis |
| –substitution_font |
A3DRWParamsPmiData::m_pcSubstitutionFont |
| –always_substitute_font |
A3DRWParamsPmiData::m_bAlwaysSubstituteFont |
| –tessellation_quality |
A3DRWParamsTessellationData::m_eTessellationLevelOfDetail |
| –read_attributes |
A3DRWParamsGeneralData::m_bReadAttributes |
| –read_geometry |
A3DRWParamsGeneralData::m_eReadGeomTessMode |
| –read_wireframes |
A3DRWParamsGeneralData::m_bReadWireframes |
| –jt_level_of_detail |
A3DRWParamsJTData::m_eReadTessellationLevelOfDetail |
| –revit_physical_properties |
A3DRWParamsRevitData::m_ePhysicalProperties |
| –ifc_import_relationships |
A3DRWParamsIFCData::m_bReadRelationships |
| –prc_brep_compression |
A3DRWParamsExportPrcData::m_bCompressBrep A3DRWParamsExportPrcData::m_eCompressBrepType |
| –prc_remove_brep |
A3DRWParamsExportPrcData::m_bRemoveBRep |
| –prc_tessellation_compression |
A3DRWParamsExportPrcData::m_bCompressTessellation |
| –step_export_format |
A3DRWParamsExportStepData::m_eStepFormat |
| –stl_ascii |
A3DRWParamsExportStlData::m_bBinaryFile |
