The following sample code insert a circle in a offscreen driver. A callback is used to retrieve circle geometry points to polylines points.
These polylines points is inserted to the main scene for validation.
Sample code is tested using PartViewer.
static HIC_Point * global_polylines_pts;
static int polyline_count;
extern "C" {
typedef void (*him_function)(HC_ANY_ARGS);
#define HIM_FUNCTION(function) (him_function)(function)
static void draw3dpolyline_cb(HIC_Rendition const *nr, HIC_Polyline const *polyline)
polyline_count = HIC_Show_Polyline_Count(polyline);
HIC_Point const* polyline_points = HIC_Show_Polyline_Points(polyline);
global_polylines_pts = new HIC_Point[polyline_count];
for (int i = 0; i < polyline_count; i++) {
char buf[1024];
sprintf(buf, "(%.2f,%.2f,%.2f)\n", polyline_points[i].x, polyline_points[i].y, polyline_points[i].z);
global_polylines_pts[i].x = polyline_points[i].x;
global_polylines_pts[i].y = polyline_points[i].y;
global_polylines_pts[i].z = polyline_points[i].z;
// global_polylines_pts will contain all polylines generated points
HIC_Draw_3D_Polyline(nr, polyline);
HC_KEY ikey;
char options[MVO_BUFFER_SIZE];
HC_Open_Segment("/driver/opengl2/image"); {
ikey = HC_Insert_Image(0, 0, 0, "rgba", 50, 50, 0);
sprintf(options, "use window id = image key = %s%p, no subscreen, no border, isolated", H_EXTRA_POINTER_FORMAT, (void *)ikey);
HC_Set_Driver_Options(options);
HC_Open_Segment("scene"); {
float position[] = { 0.0, 0.0, -5.0 };
float target[] = { 0.0, 0.0, 0.0 };
float up[] = { 0.0, 1.0, 0.0 };
float field_width = 8.0 / 3.0;
float field_height = 2.0;
HC_Set_Camera(&position, &target, &up, field_width, field_height, "orthographic");
HC_Open_Segment("model"); {
HC_Define_Callback_Name("poly", HIM_FUNCTION(draw3dpolyline_cb));
HC_Set_Callback("draw 3d polyline=poly");
HC_Set_Visibility("lines=on");
HPoint center, major, minor;
center.x = 0; center.y = 0; center.z = 0;
major.x = 1; major.y = 0; major.z = 0;
minor.x = 0; minor.y = 1; minor.z = 0;
HC_Open_Segment("circle");
HC_Insert_Elliptical_Arc(¢er, &major, &minor, 0, 1);
HC_Close_Segment();
} HC_Close_Segment();
HC_Update_One_Display("/driver/opengl2/image");
// insert polyline into the main scene
HC_Open_Segment(""); {
HC_Insert_Polyline(polyline_count, global_polylines_pts);
