Language: JavaScript
Last Version Tested: HC 2022 SP2 U1
Please note that a more robust animation example exists as part of the Communicator “quick_start” menu:
The following code is a distilled part of the animation example cited above so that it can quickly be executed in the web browser console:
// Create the Animation object
let animation = new Communicator.Animation.Animation("color_animation");
// Create the player
let player = hwv.animationManager.createPlayer(animation);
var nodeId = 67; //known node id of microengine model
var startTime = 1;
var duration = 2;
function createColorChannel (nodeId, startTime) {
const channelName = `Color-${nodeId}`;
const buffer = new Communicator.Animation.KeyframeBuffer(Communicator.Animation.KeyType.Vec3);
const sampler = new Communicator.Animation.Sampler(buffer, Communicator.Animation.InterpolationType.Linear);
const channel = animation.createNodeChannel(channelName, nodeId, Communicator.Animation.NodeProperty.Color, sampler);
// Set initial keyframe; set node color to green
let green = new Communicator.Color.green();
channel.sampler.buffer.insertVec3Keyframe(startTime, green.r, green.g, green.b);
//Change node color to blue
let blue = new Communicator.Color.blue();
channel.sampler.buffer.insertVec3Keyframe(startTime + duration, blue.r, blue.g, blue.b);
createColorChannel(nodeId, startTime);
player.reload();
player.play();
More information about using the animation API can be found in our docs. Note that as of the date of when this article was written, the animation feature is in beta release.
