How to compute intersections between NURBS and lines
Hi, I have an application where I need to find the intersections between a ray and a NURBS surface. How do I compute that.
Thanks.
Hi Qiaodong, to make sure we give you the best answer, are you looking to compute intersections between several different geometry with-in the model and a NURBS Surface or a ray outside of the geometry that returns all NURBS surfaces that intersect with that ray?
Thanks for replying. Ideally I want to raycast a Brep model that could contain NURBS surfaces, and find all intersections of the ray with the Brep model. Raycasting a triangle mesh is easy, but I’m not sure if HPS can handle ray intersections with Brep like NURBS.
Hi QCui, in Visualize, our cross platform 3d visualization SDK has a way to check for selection on different parts of model effectively casting a ray through the model and returning a list of things it intersects with, but does not provide for direct high performance NURBS surface ray casting.
