The following is sample code uses ShellKey::ShowTristrips to find the vertices of a sub-face. Please run sample code using hps_mfc_sandbox.
Replace CHPSView::OnUserCode2() (CHPSView.cpp) with the following code:
class Face
public:
Face(unsigned int v1, unsigned int v2, unsigned int v3)
_v1 = v1; _v2 = v2; _v3 = v3;
unsigned int GetV1() { return _v1; }
unsigned int GetV2() { return _v2; }
unsigned int GetV3() { return _v3; }
private:
/*unsigned int _id;*/
unsigned int _v1, _v2, _v3;
void CHPSView::OnUserCode2()
HPS::SegmentKey ModelSegKey = GetDocument()->GetModel().GetSegmentKey();
ModelSegKey.GetPerformanceControl().SetStaticModel(HPS::Performance::StaticModel::None);
HPS::SegmentKey MarkKey = ModelSegKey.Subsegment("Vertices");
ModelSegKey.GetVisibilityControl().SetMarkers(true).SetEdges(true);
ModelSegKey.GetMaterialMappingControl().SetMarkerColor(RGBColor(1, 0, 0));
ModelSegKey.GetMarkerAttributeControl().SetSymbol("circle in a circle");
HPS::ShellKey shellKey;
bool found = false;
// Search the segment for Shell
// cylinder_as_shell.hsf contain only one shell
HPS::SearchResults searchResults;
ModelSegKey.Find(HPS::Search::Type::Shell,
HPS::Search::Space::Subsegments,
searchResults);
HPS::SearchResultsIterator it = searchResults.GetIterator();
while (it.IsValid())
Key key = it.GetItem();
if (key.Type() == HPS::Type::ShellKey)
shellKey = (HPS::ShellKey)key;
found = true;
it.Next();
if (found)
HPS::SizeTArray out_faces, out_vertices, edges1, edges2;
IntArray tristrips, face_indices;
PointArray points;
shellKey.ShowTristrips(tristrips, face_indices);
shellKey.ShowPoints(points);
// assuming each face only contain 3 vertices (tri-strip)
std::vector<Face> tri_strip_flist(face_indices.size(), Face(0, 0, 0));
// Generate facelist from tristrips and face_indices
// map shellface to tri_strip_flist
size_t map_index = 0;
for (int i = 0; i < tristrips.size(); i++)
int traverse_array = i;
for (int j = 0; j < tristrips[i] - 2; j++) // generate faces
Face shellface(tristrips[traverse_array + j + 1], tristrips[traverse_array + j + 2], tristrips[traverse_array + j + 3]);
int face_number = face_indices[map_index++];
tri_strip_flist[face_number] = shellface;
i = i + tristrips[i]; // increment to end of facelist
// shellface is sorted
// Change sub-face color to red
// Insert markers separately using points found on shell
tri_strip_flist.shrink_to_fit();
size_t numFaces = tri_strip_flist.size();
for (int x = 0; x < numFaces; x++)
size_t pointoffset1 = tri_strip_flist[x].GetV1();
size_t pointoffset2 = tri_strip_flist[x].GetV2();
size_t pointoffset3 = tri_strip_flist[x].GetV3();
HPS::Point p1 = points[pointoffset1];
HPS::Point p2 = points[pointoffset2];
HPS::Point p3 = points[pointoffset3];
RGBColorArray cols;
cols.push_back(HPS::RGBColor(1, 0, 0));
HPS::SizeTArray faceArrcol;
faceArrcol.push_back(x);
shellKey.SetFaceRGBColorsByList(faceArrcol, cols);
MarkKey.InsertMarker(p1);
MarkKey.InsertMarker(p2);
MarkKey.InsertMarker(p3);
// Flush everything
MarkKey.Flush();
shellKey.UnsetFaceColors();
- Build and run hps_mfc_sandbox
- Load cylinder_as_shell.hsf
- Run OnUserCode2
cylinder_as_shell.zip (699 Bytes)
