Below is sample code on how to extract a tetrahedron shell to show only the exterior surface that have interior vertices vertices and faces.
void CSolidHoopsView::OnExtraSlot5() {
HC_KEY key;
// Input
int pcount0, face_list_length0;
float const* points0;
int const* face_list0;
// Intermediate
int pcount1, face_list_length1;
float* points1;
int* face_list1;
// Returned
int* face_list2;
int pcount2, face_list_length2;
float* points2;
HC_KEY shellkey;
m_pHView->SetViewMode(ViewMode::HViewBack);
HC_Begin_Contents_Search("...", "shells");
if (!HC_Find_Contents(0, &key)) {
m_pHView->Update();
HC_End_Contents_Search();
HC_Show_Shell_Size(key, &pcount0, &face_list_length0);
HC_Show_Geometry_Pointer(key, "points", &points0);
HC_Show_Geometry_Pointer(key, "face list", &face_list0);
pcount1 = pcount0;
face_list_length1 = face_list_length0;
face_list1 = new int[face_list_length1];
points1 = new float[3 * pcount1];
remove redundant points
HC_Compute_Optimized_Shell(
pcount0, points0, 0, face_list_length0, face_list0, "", &pcount1, points1, &face_list_length1, face_list1, 0, 0);
pcount2 = pcount1;
face_list_length2 = face_list_length1;
face_list2 = new int[face_list_length2];
points2 = new float[3 * pcount2];
Compute skin on shell
HC_Compute_Optimized_Shell(pcount1,
points1,
0,
face_list_length1,
face_list1,
"skin",
&pcount2,
points2,
&face_list_length2,
face_list2,
0,
0);
Insert shell to see result
HC_Open_Segment("skin_shell"); {
HC_Set_Color("faces = yellow, edges=black");
HC_Translate_Object(0, 0, 2);
HC_Insert_Shell(pcount2, points2, face_list_length2, face_list2);
}HC_Close_Segment();
delete[] points1;
delete[] points2;
delete[] face_list1;
delete[] face_list2;
HUtilityGeometryCreation::CreateCuttingPlane(m_pHView, "plane3");
m_pHView->SetGeometryChanged();
m_pHView->FitWorldExact();
m_pHView->Update();
HC_Open_Segment_By_Key(m_pHView->GetWindowspaceKey()); {
HC_Insert_Text(-0.3f, -0.8f, 0, "Original shell");
HC_Insert_Text(0.3f, -0.8f, 0, "Optimized shell");
m_pHView->Update();
Result:
