Language: C++
Sample code of extracting cutting plane geometry for mfc_sandbox.
Cutting Sections — HOOPS Visualize HPS Documentation 2022.0.0 documentation
Instructions
- Open \samples\data\turbine.hsf
- Run the user code below
void CHPSView::OnUserCode()
HPS::SegmentKey mySegmentKey = GetCanvas().GetFrontView().GetSegmentKey();
// enable visibility of cut geometry
mySegmentKey.GetVisibilityControl().SetCutGeometry(true);
// set the cutting depth for cutting section
mySegmentKey.GetCuttingSectionAttributeControl()
.SetCappingLevel(HPS::CuttingSection::CappingLevel::Segment)
.SetCuttingLevel(HPS::CuttingSection::CuttingLevel::Global);
// insert cutting section
HPS::CuttingSectionKey cutterKey = mySegmentKey.InsertCuttingSection(HPS::Plane(HPS::Vector(1, 0, 0)));
// Call update
GetCanvas().GetFrontView().UpdateWithNotifier().Wait();
// set gather depth
HPS::CutGeometryGatheringOptionsKit opt;
opt.SetLevel(CuttingSection::GatheringLevel::Segment);
// build path
HPS::SprocketPath sprocket_path(GetCanvas(), GetCanvas().GetAttachedLayout(), GetCanvas().GetFrontView(), GetCanvas().GetFrontView().GetAttachedModel());
// put cut geometry into subsegment called "caps"
sprocket_path.GetKeyPath().GatherCutGeometry(mySegmentKey.Subsegment("caps"), opt);
// delete model to leave just the caps in place (optional)
GetCanvas().GetFrontView().GetAttachedModel().Delete();
GetCanvas().Update();
You need an update before gathering the cut geometry to get geometries.
