Following is sample code on Gather_Capping_Geometry with all options (“segment only”,”ignore matrix”, “section offset”, “refine cuts”
Default: HC_Gather_Capping_Geometry will only generate capping geometry for the given cutting plane.
Common Errors:
- HOOPS need to render capping geometry. Update must be called before calling Gather_Capping_Geometry
- Double check key path. Make sure key path is from the leaf to root (driver) segment.
OPTIONS
Segment Only: Collect capping geometry only for the target segment, not any of its subsegments
void CSolidHoopsView::OnExtraSlot5()
int pcount, flist_count;
pcount = 8;
flist_count = 30;
HPoint pts[8];
int faces[30] = { 4, 0, 1, 2, 3,
4, 1, 5, 6, 2,
4, 5, 4, 7, 6,
4, 4, 0, 3, 7,
4, 3, 2, 6, 7,
4, 0, 4, 5, 1 };
pts[0].Set(0, 0, 0);
pts[1].Set(2, 0, 0);
pts[2].Set(2, 2, 0);
pts[3].Set(0, 2, 0);
pts[4].Set(0, 0, 2);
pts[5].Set(2, 0, 2);
pts[6].Set(2, 2, 2);
pts[7].Set(0, 2, 2);
float planes[] = { 0, 0, -1, -0.0001, 1, 0, 0, -0.0001, 0, 1, 0, -0.0001 };
HC_KEY cutplaneSegment = HC_Open_Segment("cut_plane");
HC_KEY section = HC_Insert_Cutting_Plane(0, 0, -1, -0.0001);
float center[] = { 5, 0, 0 };
HC_Insert_Sphere(center, 2, NULL, NULL);
HC_Insert_Cutting_Plane(1, 0, 0, -0.0001);
HC_Open_Segment("section cuts y");
HC_Insert_Shell(pcount, pts, flist_count, faces);
HC_Translate_Object(-1, -1, -1); // translate to origin
HC_Close_Segment();
HC_Close_Segment();
// In order for HC_Gather_Capping_Geometry to work, calling UPDATE is mandatory
m_pHView->Update();
// key path from shell to SceneKey
HC_KEY keypath[4] = { cutplaneSegment, m_pHView->GetModelKey(), m_pHView->GetIncludeLinkKey(), m_pHView->GetSceneKey() };
HC_Open_Segment("segment only");
HC_Gather_Capping_Geometry(4, keypath, section, "segment only");
HC_Set_Color("face=(red,transmission=gray)");
HC_Close_Segment();
HC_Open_Segment("default");
HC_Gather_Capping_Geometry(4, keypath, section, "");
HC_Set_Color("face=(blue,transmission=blue)");
HC_Translate_Object(0, 5, 0);
HC_Close_Segment();
// Delete cut pland and box to see capping geometry
HC_Delete_By_Key(cutplaneSegment);
} HC_Close_Segment();
m_pHView->Update();
Ignore Matrix:
Section Offset: This option is only valid when you inserted a “cutting section”. This option will let you specify a single plane offset.
pcount = 8;
flist_count = 30;
HPoint pts[8];
4, 1, 5, 6, 2,
4, 5, 4, 7, 6,
4, 4, 0, 3, 7,
4, 3, 2, 6, 7,
4, 0, 4, 5, 1 };
HC_KEY section = HC_Insert_Cutting_Section(3, planes);
HC_Close_Segment();
HC_Close_Segment();
m_pHView->Update();
HC_Open_Segment("section cuts x");
HC_Gather_Capping_Geometry(4, keypath, section, "section offset = 1, refine cuts");
HC_Set_Color("face=(green,transmission=gray)");
HC_Close_Segment();
HC_Gather_Capping_Geometry(4, keypath, section, "section offset = 2, refine cuts");
HC_Set_Color("face=(blue,transmission=gray)");
HC_Close_Segment();
HC_Open_Segment("section cuts z");
HC_Gather_Capping_Geometry(4, keypath, section, "section offset = 0, refine cuts");
HC_Close_Segment();
m_pHView->Update();
Refine Cuts: This option will determine if capping geometry will be refine by all cutting planes in scene. Default (OFF), capping geometry is only generate by one cutting plane
pcount = 8;
flist_count = 30;
HPoint pts[8];
4, 1, 5, 6, 2,
4, 5, 4, 7, 6,
4, 4, 0, 3, 7,
4, 3, 2, 6, 7,
4, 0, 4, 5, 1 };
HC_Close_Segment();
HC_Close_Segment();
m_pHView->Update();
HC_Open_Segment("section cuts");
HC_Gather_Capping_Geometry(4, keypath, section, "refine cuts");
HC_Close_Segment();
HC_Open_Segment("section default");
HC_Close_Segment();
m_pHView->Update();
