Below is a sample code snippet demonstrating how to use OOC::Preprocessor to create an .OOC file.
Note: The data needs to be processed in two passes:
- First Pass: Read your data to determine the minimum and maximum values of your points. These values are required to call
OOC::Processor::SetCullingBoundingBox(min, max). - Second Pass: Add your points and create the
.OOCfile.
PointCloud.txt
231.184304018609;28.0413952188606;-52.9060268489888
230.519663194219;27.8575831696436;-53.1020735257726
180.846926122318;14.4033549613675;-65.8973115452756
180.645231895336;14.346701878569;-65.9614782676344
169.487355959823;11.1314395604915;-70.0178583075153
167.585456214966;10.5698552222266;-70.7934752619902
158.059809849517;7.78309520406801;-74.5002518418382
137.452405113955;1.9655581066296;-81.1235261654424
137.239202967066;1.91407596863235;-81.1359134738528
137.007460149156;1.86437470324587;-81.1090716382481
Sample Code:
#include <fstream>
#include <sstream>
#include <climits>
using namespace ooc;
using namespace ooc::preprocess;
static std::string& strip(std::string& s)
s.erase(std::remove(s.begin(), s.end(), ','), s.end());
return s;
void CSolidHoopsView::OnExtraSlot5() {
std::string str_buf;
std::string str_x, str_y, str_z;
std::string input_csv_file_path = "D:\\ooc\\PointCloud.txt";
std::ifstream ifs_csv_file(input_csv_file_path);
double bbox[6];
bbox[0] = bbox[1] = bbox[2] = +(std::numeric_limits<double>::max)();
bbox[3] = bbox[4] = bbox[5] = -(std::numeric_limits<double>::max)();
HPoint points[55000];
// initialize preprocessor with output file
Preprocessor preprocessor(L"D:\\ooc\\pt_cloud.ooc");
int total_points = 0;
int counter = 0;
float p[3];
while (getline(ifs_csv_file, str_buf) && total_points <=60000000)
std::istringstream i_stream(str_buf);
getline(i_stream, str_x, ';');
getline(i_stream, str_y, ';');
getline(i_stream, str_z, ';');
p[0] = std::stof(strip(str_x));
p[1] = std::stof(strip(str_y));
p[2] = std::stof(strip(str_z));
total_points++;
for (int i = 0; i < 3; ++i) {
if (p[i] < bbox[i + 0])
bbox[i + 0] = p[i];
if (p[i] > bbox[i + 3])
bbox[i + 3] = p[i];
// preprocessor.AddPoints(1, p);
ooc::Point culling_min((float)bbox[0], (float)bbox[1], (float)bbox[2]);
ooc::Point culling_max((float)bbox[3], (float)bbox[4], (float)bbox[5]);
preprocessor.SetCullingBoundingBox(culling_min, culling_max);
preprocessor.Initialize();
ifs_csv_file.close();
total_points = 0;
ifs_csv_file.open(input_csv_file_path);
while (getline(ifs_csv_file, str_buf) && total_points <= 60000000)
total_points++;
preprocessor.Export();
