How to set the camera position
I want to change the location of the camera a little when I click the button.
var cam = hwv.view.getCamera()
then,
I tried to use setCamera() by setting coordinates using setPosition(), but failed.
and
Is there a file or document that summarizes the functions attached below from the communicator I downloaded?
It’s not easy to find
Please give me some advice
Thanks
Hello @jhbae,
Since you did not provide code on how you are using setPosition, we can’t confirm how it is being used. Worth pointing out is that setPosition requires a Communicator.Point3 object as the argument to the function.
As a quick example, this code snippet below will NOT work and the camera position variable will be undefined:
var cam = hwv.view.getCamera();
var camVar = 0.01;
cam.setPosition(cam.getPosition().x + camVar, cam.getPosition().y + camVar, cam.getPosition().z + camVar);
hwv.view.setCamera(cam);
But this will work when creating a Point3 object:
var camVar = 0.01;
cam.setPosition(new Communicator.Point3(cam.getPosition().x + camVar, cam.getPosition().y + camVar, cam.getPosition().z + camVar));
WIth respect to documentation on the main navigation bar of the Web Viewer, there is not a centralized location for that. I can notify our docs team about making changes. All that being said, the navigation bar does have mouseover tooltip functionality which provides additional information on the specific icons.
I found the functions I was curious about by referring to the tooltip functionality. Thank you
