Hi everyone,
I’m encountering an issue when trying to run the following code:
try {
await viewer.model.setNodeMatrix(nodeId, result);
} catch (error) {
console.log('IafMathUtils.translateNode', error);
This works fine on smaller nodes, but when I attempt it on the root node of a large model, I receive the following error:
abort("Cannot enlarge memory arrays. Either (1) compile with -s TOTAL_MEMORY=X
with X higher than the current value 2147418112,
(2) compile with -s ALLOW_MEMORY_GROWTH=1 which allows increasing the size at runtime,
or (3) if you want malloc to return NULL (0) instead of this abort,
compile with -s ABORTING_MALLOC=0 ").
Build with -s ASSERTIONS=1 for more info.
Questions:
- Is this related to WebAssembly memory limits? if so how to address?
- Any other suggested workarounds when working with large models in a viewer?
