Is there a built-in way to customize the appearance of the NavCube and AxisTriad, such as changing their colors, transparency, labels, or style?
Hello @praful.bharate,
There is not an interface to customize the appearance of the AxisTriad. With respect to the NavCube customization, there is a proof-of-concept implementation based on the NavCube source code. Please refer to this previous post:
Hi @tino ,
Thank you for sharing the details. I have reviewed the POC and wanted to ask if it’s possible to provide the TypeScript files instead of the JavaScript version for CustomNavCube.js. Additionally, could you confirm whether this code is compatible with the latest version of HOOPS Communicator?
A TypeScript version is not available for CustomNavCube.js.
Only minor changes are required to the JavaScript file are required in order to use it for recent Communicator versions:
Communicator.OverlayUnitPointbecomesCommunicator.Overlay.OverlayUnitPoint- Add
import * as Communicator from "./your_directory_to/hoops-web-viewer.mjs";
Thankyou @tino for the suggestions.
