3DF: How to encrypt HSF file using
Version
3DF v.2X.XX
Language
C++
Description:
Below is sample code on how to encrypt your hsf file so that only your application can import hsf file.
  • You can use PartViewer to test sample.
#include "HStream.h"
class encyrptHSF : public BBaseOpcodeHandler
       public:
              encyrptHSF() : BBaseOpcodeHandler(0xB0) {
              ~encyrptHSF() {};
              TK_Status     Interpret(BStreamFileToolkit &, ID_Key, int) {
                     return TK_Normal;
              TK_Status     Execute (BStreamFileToolkit &) {
                     return TK_Normal;
              TK_Status     Read (BStreamFileToolkit & tk) {
                     TK_Status       status = TK_Normal;
                     switch (m_stage) {
                           case 0: {
                                  unsigned char       bytes[13];
                                  if ((status = GetData (tk, bytes, 13)) != TK_Normal)
                                         return status;
                                  m_stage = -1;
                           }   break;
                           default:
                                  return tk.Error();
                     return TK_Normal;
              TK_Status     Write (BStreamFileToolkit & tk) {
                     switch (m_stage) {
                           case 0: {
                                  if ((status = PutOpcode (tk)) != TK_Normal)
                                         return status;
                                  m_stage++;
                           }   //nobreak;
                           case 1: {
                                  unsigned char       bytes[13] = {0, ')', '(', 0x7F, 0, ';', ' ', 'H', 'S', 'F', ' ', '1', '3'};
                                  if ((status = PutData (tk, bytes, 13)) != TK_Normal)
                                         return status;
                                  m_stage = -1;
                           }   break;
                           default:
                                  return tk.Error();
                     return TK_Normal;
static char const *  filename = "D:/encyrptHSFed.hsf";
//  Export
       HStreamFileToolkit   tk;
       tk.SetPrewalkHandler (new encyrptHSF);
       HC_Open_Segment_By_Key (m_pHView->GetModelKey());
              HTK_Write_Stream_File (filename, &tk);
       HC_Close_Segment ();
//  Import
void CSolidHoopsView::OnExtraSlot2()
       tk.SetOpcodeHandler (0xB0, new encyrptHSF);
              HTK_Read_Stream_File (filename, &tk);
       m_pHView->FitWorld();
       m_pHView->Update();
