Error: No status file
A “no status file” error in the Web Viewer when trying to load a model indicates an issue with your stream cache directory. It’s usually one of the following:
  • The root file in your stream cache is corrupt/damaged/not there
  • The stream cache directory is not accessible from your viewing instances
  • The stream cache directory does not exist
  • The stream cache directory was not specific correctly in your settings file
