Problem
When importing a 3D-PDF file, HOOPS Exchange returns an error.
Solution
The 3D-PDF is protected:
HOOPS Exchange can’t import a 3D-PDF if it is password protected : HOOPS Exchange, PDF Reader specifications
To check if a PDF is protected:
- Open the PDF in Adobe Acrobat.
- Look at the window title bar, and search for the mention
(PROTECTED)
The 3D data are corrupted:
Open the 3D-PDF file in Adobe Acrobat. If the 3D can’t be displayed, the data are corrupted.
HOOPS Exchange won’t be able to import these data.
The 3D-PDF is working correctly in Acrobat and is not protected:
Please report the issue to Tech Soft 3D support.
- Explain which error you are getting
- Indicate HOOPS Exchange version
- Attach the PDF file
- If it is known, please mention which software was used to create the 3D PDF file
- If it is possible, please share the original 3D file use to create the 3D PDF file
