Not sure if this is a Communicator or an Exchange server question.
I can’t find anywhere on how to do this. I tried running the converter from /authoring/converter/bin/linux64but it gave me an error:
[09/22/2025 11-23-08-000 D:0 PID:43463 M:1264MB]ERROR 0: This file appears to contain only 2D information. Exporting to 3D formats is not supported.
How do you convert DXF/DWG 2D or 3D files to STEP/SCS files on exchange? Is this possible? Or are we stuck for only supporting 3D files as input?
Thank you!
Edit: There is also something called ImportExport.cpp in HOOPS_Exchange_Publish_2024.5.0/samples/exchange/exchangesource. Can this be used? How do I use this?
Edit 2:
Tried following these instructions 1. Set Up Your Environment — HOOPS Exchange Documentation
ran:
~/Downloads/HOOPS_Exchange_Publish_2024.5.0_Lin/HOOPS_Exchange_Publish_2024.5.0/samples/exchange/exchangesource/ImportExport$ ./ImportExport ..\samples\data\catiaV5_Aquo Bottle.CATProduct ..\samples\data\catiaV5_Aquo Bottle.CATProduct.prc
Got this error:
ERROR: ../../../../bin/linux64/libA3DLIBS.so: cannot open shared object file: No such file or directory
sHoopsExchangeLoader.m_eSDKStatus returned error -1
Even though libA3DLIBS.so file is present in that folder…
