Running HOOPS Communicator Converter command in Windows error
Hi there,
I am trying to convert sample .dwg to .scs using communicator-converter in windows 11.
I have attached the error below.
[04/07/2025 09-42-07-105 D:171338020 PID:19524 M:16MB]INFO 0: Command Line = C:\PROJECT\HOOPS_Communicator_2024.7.1\authoring\converter\bin\win64\converter.exe --input C:\Users\chenk\Documents\CAD\45[04/07/2025 09-42-07-105 D:-535582396 PID:19524 M:17MB:]INFO: HOOPS Converter v24.7 - SC v74 Build 9a76196
        [04/07/2025 09-42-07-110 D:000000 PID:19524 M:17MB:]INFO: Component initialization
                [04/07/2025 09-42-07-110 D:000000 PID:19524 M:17MB:]INFO: Initializing HPS::World
                [04/07/2025 09-42-07-268 D:-535582396 PID:19524 M:23MB:]INFO: Initializing Exchange
[04/07/2025 09-42-07-292 D:000000 PID:19524 M:23MB]ERROR 0: Failed to load the Exchange SDK
[04/07/2025 09-42-07-292 D:000000 PID:19524 M:23MB]ERROR 1: Component initialization failure
        [04/07/2025 09-42-07-404 D:000293 PID:19524 M:23MB:]INFO: Exiting: Conversion failed
Unfortunately we were unable to convert this model.
I am a beginner, learning quickly from documents
Thanks in advance.
Hello @chenkangck15,
It does not look like you are supplying a complete set of parameters to converter.exe for it to complete the operation. At minimum, you must provide --input, --output_scs and --license. For the first two parameters, you must include the file format extension (.dwg, .scs), for example, your_dwg.dwg and your_dwg.scs.
Perhaps an easier approach is to use the drag-and-drop utility batch file provided in the Communicator package. More information can be found here.
thank you for your answer.What is confusing is that I actually dragged the dmp file to the convert_file.bat batch file in the Communicator package. Is it because my computer is not configured with some environment?
I also downloaded the Communicator package from the official website. I tried HOOPS Communicator 2025.2.0, HOOPS Communicator 2025.1.0, and HOOPS Communicator 2024.7.1. I dragged the file to quick_start/convert_file.bat, and the output was the same as above. So I wonder if I missed some steps.
If you have any ideas, please let me know. Looking forward to your reply.
Thanks again,
ChenKang
For the Web Viewer, Visual Studio C++ redistributables are required as mentioned in our docs. For converter, if the redistributables are missing, you will receive a message to the effect of VCRUNTIME141.dll is missing (which is different from the message that you are getting).
The issue might be the DWG file itself. As part of the HC package, there are various CAD files included. Can you try the drag-and-drop conversion operation for the file HotelFloorplan.dwg found in the directory HOOPS_Communicator_202X.x.0\authoring\converter\example\_data?
I attempted this but encountered same error. Here’s the error message:
[04/09/2025 13-21-22-353 D:316344207 PID:2540 M:16MB]INFO 0: Command Line = C:\PROJECT\HOOPS_Communicator_2024.7.1\authoring\converter\bin\win64\converter.exe --input C:\PROJECT\HOOPS_Communicator_2024.7.1\authoring\converter\example\_data\HotelFloorplan.dwg --license 4CYZwSQKxvY25SiV0BJ8DAN9xBQzCw7bvUjuAuMK2w3zDCeW_DXMjAYP1CEM8U7oCinmrBRyAU34Binm7UVyCdEKDhJvCTJ3ByLFjEUNBfiYDUaJ2xIX3RiJvEI50BnyCS7rxTUT1wm3BUMH4gby1gBd9zeTDU250g640DiPBgm30UmZByQV9yIT5xqL0AMIBARxBgRvDgAG1hrlDBM_3weJxfa8DCM18SBazTY0AxYEj7DFwwZn43dQj7Fl5TRlWslFjBVu3BTGj7DFj7DFjJPOj7DFj7DFWslFjHmPIqQR2i798Ey02gjwzQV16gQIwE6ZwUN22CY40Ue5wDnmBEeI1RZk2DZ14EFz7UiW2QVuBSQ5xfi8vEnx8CUz3Tnr5sQYzyYgj7DFDrHFjBU0BUYK3xm2AwQRzQQI5Uj0ARM6xwZ2xCB$1SA8zS371g75vSQ20SQ6AeQ25uRm9giK2EyK2fn44SaW4Ufo1EJ2vAEI0AYSvU2O2eYS9FiIBBbdxxbpDji00yv55Dm80xaUBi3m5w33DTQ45AYPvSz6ByiMDCZz0Ub$1SMOwiz6AijyxEvn0wQ54hQ02SYY0vn$9yu6zUy53hQS4fR26fIM3EzyBhe5xUm3CUv00wQ30SZcCyndDjb0xCyPwEmKEhnpCgAIxgZc9Djd8Tm49Vbp5gfl9EAUCwv$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 --output_sc C:\PROJECT\HOOPS_Communicator_2024.7.1\quick_start\converted_models\user\sc_models\HotelFloorplan --output_scs C:\PROJECT\HOOPS_Communicator_2024.7.1\quick_start\converted_models\user\scs_models\HotelFloorplan.scs --sc_create_scz 1 --sc_compress_scz 1 --output_png C:\PROJECT\HOOPS_Communicator_2024.7.1\quick_start\converted_models\user\images\HotelFloorplan.png --background_color 0.75,0.86,0.97 --output_png_resolution 320x240 --load_all_configurations 1 --sc_export_attributes 1
[04/09/2025 13-21-22-353 D:-74302908 PID:2540 M:17MB:]INFO: HOOPS Converter v24.7 - SC v74 Build 9a76196
        [04/09/2025 13-21-22-353 D:000000 PID:2540 M:17MB:]INFO: Component initialization
                [04/09/2025 13-21-22-353 D:000000 PID:2540 M:17MB:]INFO: Initializing HPS::World
                [04/09/2025 13-21-22-514 D:-74302908 PID:2540 M:23MB:]INFO: Initializing Exchange
[04/09/2025 13-21-22-538 D:000000 PID:2540 M:23MB]ERROR 0: Failed to load the Exchange SDK
[04/09/2025 13-21-22-538 D:000000 PID:2540 M:23MB]ERROR 1: Component initialization failure
        [04/09/2025 13-21-22-637 D:000284 PID:2540 M:23MB:]INFO: Exiting: Conversion failed
Thanks for the update.
One other suggestion is to install the necessary Visual Studio C++ Redistributable. Please download and install the x64 version (vc_redist.x64.exe) found in this page.
Hi Tino,
Thank you so much for your suggestion! I followed the method you provided and successfully solved this problem. It’s really appreciated.
Best regards,
ChenKang
