Inventor OEM 2023, no .RVT file output – workaround provided
There’s a bug in the Revit workflow in Inventor OEM. The expected .RVT file is not created at all.
Scenario, using an Inventor assembly (.iam):
The output is showed in the Assembly tree structure:
No file in the target folder:
Workaround/solution:
Copy attached file (Autodesk.TranslatorRVTImport.Inventor.addin) to
c:\ProgramData\Autodesk\Inventor OEM 2023\Addins
all Revit workflows should work after doing that
To make this work in a deployed custom Inventor OEM based product it needs to be rebuilt from the configurator.
Autodesk.TranslatorRVTImport.Inventor.zip (1.3 KB)
This is a great solution thanks for sharing!
