Is the model file damaged or is there any other possible reason?
Hello @619944680,
It is possible the model file is corrupt which is triggering the error message Unknown opcode. You can try loading the source CAD file in a native viewer to confirm if that is the case.
Also, under what context is the error message being triggered? For example, did you recently upgrade to a newer version of Communicator and just now, you are getting the error message?
I am using an RVT model file, which can be opened in Revit2018, but cannot be opened above Revit2018, possibly due to a damaged model file.
The conditions for triggering the error are currently uncertain and may occur irregularly. I’ll double check.
Thans,Tino.
